Upper control arm question
str8fast
Rio Linda
Sick of alignment issues with the lower arms. Gonna make those pivot points solid and get a set of aftermarket uppers. Am I going to be able to have enough adjustment in the heims on the uppers to get the truck aligned? I would assume I install upper arms with the heims in the middle of the adjustment range then get the truck aligned as usual on the lower sliders. At that point I weld the washers in on the lowers?
KaiserM715
Kaiser Söze
Do be aware that some of the aftermarket uppers require the bolts be pulled to turn the heims for alignment. I have an idea about which ones are easily adjusted on the truck, but I'm not 100%.... I am guessing most alignment shops aren't going to want to pull the shocks to align it... Do your research beforehand.
str8fast
str8fast
Rio Linda
Yes I am aware of this. I'm hoping that with getting rid of the slots on the lower control arms I won't knock it out of alignment every other day. Set it once and be done other than bending parts or toe in/out adjustment
Madcowranch
Genetically Modified
OK
Do you have the alignment cam kit? Maybe I'm the exception but I just had my alignment checked after 2 years and 5 Raptor Runs and everything was still spot on. Couple times a year I retorque the LCA bolts.
str8fast
str8fast
Rio Linda
No I do not maybe should look into that before I go the upper control route. Where did you get yours from?
Deleted member 12951
Yes that is the theory. The only ones that I am aware of that allow adjustment while on the truck is ICON and SVC (I think). I have Rogue because it works with stock wheels, those other two do not. If you look on Rogue's website for the install instructions they give how many turn outs need to be done on the UCA then do the alignment and use slot deletes to permanently lock it in place or weld in your case. I would recommend upgrading the knuckles to a gussetted one or an aftermarket one. If not, a slightly bent knuckle will be more difficult to correct if you have things welded/permanently done.
I always love how doing one mod that seems like no big deal leads to modding the next thing and continues as our bank accounts funds these endeavors.
---------- Post added at 01:17 PM ---------- Previous post was at 01:14 PM ----------
I got the alignment cam kit from Amazon. The common one is from Speciality Products if I recall. SDHQ I believe has an even better kit that reinforces the LCA and provides longer bolts.
---------- Post added at 01:22 PM ---------- Previous post was at 01:17 PM ----------
Here you go!
http://store.sdhqoffroad.com/lowera-armdoublerplates.aspx
svt_reid
north florida
I have a questions slightly related to this also. Upgrading UCAs and I've heard some say you can remove them without pulling the shock. but I've heard more people say you gotta pull the shock first. Just by eyeballing it, I don't see how I can remove the UCA without pulling the shock. Can anyone tell me "yes you can only remove the arm and not the shock because I've done it" or is this all some urban legend
Madcowranch
OK
You still have to remove the top shock bolts to be able to drop the shock enough to get the UCA bolts out. I just did it. BUT, It's a bitch. It'd be easier just to go ahead and remove the lower shock bolt.
