Seeking GPS Advice/Suggestions
Dan06
The Dark Side of The Moon
Need to make a decision soonish. Which is the best way to mount a Lowrance GPS?
-Ram adjustable mount
-LGE/CTS style folding mount
(This is what I'm leaning towards, but it was pointed out it will block some of the drivers vision. Does anyone have input?)
-OR any other ideas?
(It'll be custom regardless so any ideas you have are good ideas.)
I do want it to be accessible from the drivers seat.
Thanks
BABaracus
Los Angeles, CA
I too have the LGE/CTS mount on a HDS 7 touch and I don't feel it blocks any vision. I don't really fold it down either as you need to disconnect the cables in order to fold it down on the HDS 7.
shooterAMG
Far northern Chicago suburbs
I built a "custom" RAM mount from their parts. I like that I can remove it easily. During Snoball pre-run and run, plus the Spring 14, it's never moved or fallen off. The suction cup keeps it in place and i have it rest on the dash.
JayLV
Las Vegas
I got the Outlaw Offroad mount, we decided not to use it. Basically used the included mounting bracket and mounted it towards the front part of the speaker on the dash. It swivels so it can be used by the passenger or driver pretty easily.
rap67
SE michigan and Arkansas
I run the LGE/CTS mount and I'm very pleased with it. It does not obstruct my vision.
same,
BTW I have the HDS 7 touch and could not roll it back as advertised without smashing the cables and putting a lot of stress on the connection. so I took out the lower bolts, tighten the knobs so it doesn't move and when i need to roll it back i loosen it, pull the bottom out first and lay it down, then secure the knobs again.
i like it a lot.
Dan06
Dan06
I'll probably do something in the folding mount style, since no one has negative comments. Someone just strongly stated it blocked the lower corner passenger side of the windshield, which made me second guess it. It'll be custom, so does anyone with the LGE/CTS mount have anything they wish could be changed or modified? More easily folded down is obviously one I assume. I also have a Lowrance 7 touch.
rap67
not off the cuff. Its a well thought out mount, sits in line with the NAV screen below it and I think makes the center stack look finished.
93,202
56,485
bjorn-dpc
