WSI spankin' new behind the grill mount install.
Theproperedneck
Theproperedneck
CT/NH
They are currently in production if you call him up he'll hook you up. The pioneers have the flood lense installed and man they are bright.
Yukon Joe
Trafford, PA
They are bright. Both setups looked good at snoball.
Although personally I'd go with spot behind the grill. The grill already diffuses the light enough.
Yukon Joe
www.RUNRAPTORRUN.com
Labraptor
Illinois
Whelen lights will come with lenses to do spot, flood or combination. You don't have to choose just change if you want. I would agree with Joe just leave them as spot behind the grill.
WRCRaptor
Great Lakes
0 it runs fine
What ambient temps have you run it in so far? I am sure there is some reduction in air flow as there is when other lights are run behind the grill. There is a lot more metal in this set up then a normal grill mounted light bar. It looks very nice but I fear that in the heat of the summer the radiator and other coolers will run hotter then without.
I like it just wondering.
