WSI spankin' new behind the grill mount install.
CB Freshness
South Carolina
What ambient temps have you run it in so far? I am sure there is some reduction in air flow as there is when other lights are run behind the grill. There is a lot more metal in this set up then a normal grill mounted light bar. It looks very nice but I fear that in the heat of the summer the radiator and other coolers will run hotter then without. I like it just wondering.
I haven't run to hot outside yet due to current conditions. But the pictures make it look much different. In the pictures it looks almost flush with the radiator when it's actually quite close to the grill. I've been running my truck pretty hard to try and make it overheat even at snoball redlining in 4wd breaking trail no budge
WRCRaptor
Great Lakes
Got it I guess it has been cold everywhere lately. Maybe someone in the southwest will buy it and let us know how it works in the desert.
Theproperedneck
Theproperedneck
CT/NH
The warmest I've run mine in is 45 degrees and have seen no change in normal running temps. as cb said it sits away from the radiators a good amount. I also have 2 micros on either side of my license plate which constricts air flow even more. I've seen guys run multiple bars behind the grill in hot texas weather and have no issue. The slim lines are much shorter and allow airflow in between each light head where the bars don't.
WRCRaptor
Great Lakes
Thanks for the feedback. I have a 21" in the stk lower grill with no issues. Just wondering about adding this and how it will do in hot weather so I will wait for future (summer type) feed back.
It looks good and wished I had won it at snowball to try it out.
CB Freshness
South Carolina
Thanks for the feedback. I have a 21" in the stk lower grill with no issues. Just wondering about adding this and how it will do in hot weather so I will wait for future (summer type) feed back. It looks good and wished I had won it at snowball to try it out.
I wish I had won the damn lights
