NEED HELP ASAP, hooking up my amp remote wire to Aux switch 4
vosschs
Hey guys, I have my truck apart, I see the empty wires behind the glove box. I want to hook the remote wire from the amp to Aux switch 4 so that has to be on for power. How do I go about doing this? I just have the remote wire sitting behind the dash now....everything else is hooked up.
Stepside
Do a search on upfitter switches.
There is also a good write-up on the z-forum.
http://www.************.com/showthread.php?t=17877
Now, :birgits_tiredcoffeeif i was over there and told you to come over here at FRF
the staff over there would admonish me and I would forever be
cursed with the **** of a thousand camels cascading upon my bedspread. ~ :eek:
Hockster
My 45ft Bluewater Party
Winchester, Va
cursed with the **** of a thousand camels cascading upon my bedspread.: ~ eek:
You are kidding right... the z ha ha.. Ok the staff wont but I will... ha ha... That place is as dead as MJ...
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
Here is Ironmans video he posted...
http://www.fordraptorforum.com/f12/pass-thru-wires-155/
Stepside
Hey . :laughing1:.. that place may be dead, but that particular thread is still worth one's time to look at when seeking info on upfitter wiring.
And time is worth money $$. . . like MJ is dead . . but still worth bookoo-bucks!
dataustin
If I may, I think he was saying that we have a few good, informational threads on this site so there's no need to refer someone elsewhere....
Hockster
Winchester, Va
Ya but its run by that clay aikens and hes a total ******* to the 10th degree
V
vosschs
OK so from my understanding, I will just solder the remote wire into one of the empty sets under the glove box which will then consist of 3 wires, my remote, the wire the goes to the switch and the wire that goes to the engine compartment. Then I just hook the respective wire under the hood up to create the power connection?
Would this work well with a remote wire from and amplifier?
dataustin
So.....as it comes from the factory, each of the aux wires behind the glovebox are "hot". If you want power outside tha cab you connect them to the four wires going thru the firewall. If not, connect anyone of them (they are all fused to different power levels) to the positive wire from your device and connect the device ground lead to a nearby ground to complete the circuit.
Does that make sense?
aka grumpy car stereo guy
whats wrong with going to accessory under the dash? why does an amp need to be on the switch?
NickPic83
Rockland County NY
My thought exactly. There us a fuse box by the passenger footwell. Plenty spots to do a add a fuse for keyed power...that's what I did
Sent from my DROID RAZR using Tapatalk 2
93,278
56,567
erikn
