Eibach lift springs
mberger111
Rexburg, ID
Are you from Eibach? I'd be interested to hear your thoughts on some of my concerns.
Just jumping in here to answer any questions you may have, as well as clear this up:
-The actual height measured at install is +2.5"
As you can see from our development data,(and in @ZaneMasterX's original post) the difference in hub center to fender height is 64mm.
Kits are now in stock and shipping!
mberger111
Rexburg, ID
Are you from Eibach? Oops didn't mean to post twice
Right on, thank you for the fix. Do you still have the post you read that info from?
Whoot! Make sure to take photos during the install and share them with the crew on here. If you post on social, please be sure to tag us so we can show it off for you.
MrK
Corona, CA
Yes indeed I am! Unfortunately I've not been gifted with the left brain smarts of our Engineers, but I'll do my best to help.
-We did not develop springs for the Gen1's, thus, we've never had that vehicle in the shop. What we HAVE done is tested this vehicle in both 4x4 and 4x2 with no findings of the CV or Differential binding.
- Every spring that comes through our facility is pre-set before they leave the building, meaning there should be no change in height or rate over time.
-All of our new PRO-LIFT-KIT spring systems feature a slight increase (max 10%) in rate to accommodate for aftermarket accessories. A large percentage of customers will add a winch, lights, armor, or bars to the front of the vehicle resulting in a loss of height. Combine that with a slight lift in the rear and you're back to the factory rake. Our goal is to create a spring package that hits a perfect balance of comfort and capability so you only need to buy parts once.
- Your concern about predictability off-road could largely be attributed to lack of proper alignment.
- These are linear rate springs.
MrK
Corona, CA
Only the ones who put fake carbon fiber stickers on do that.
now, now, everyone has their own taste.
I personally prefer to use my toys for what they're intended for. Unfortunately that turns this into a very expensive hobby.
Speaking of which, where is everyone from? I'm thinking about putting together an open house early one morning then heading out to the trails. You guys can see where and how these springs are made.
