- Joined
- Feb 16, 2017
- Posts
- 1,781
- Reaction score
- 1,122
Hi Guy,
In one of your previous posts you mentioned you put poly fill in your sub box. I noticed mine came with some blue 'fill' in it already. How much poly fill did you put in it?
I ripped out The piece of carpet from the factory... I call it carpet because it looked like carpet pad.
I then tucked two handfuls of polyfill in the far end of the enclosure.
I experimented with a lot and removed until the I hit the sweet spot. Too much.... it's muffled. Just right.... the bass is deeper without losing any volume.
About two good handfuls tucked in the end did the trick.
Then wrapping the whole thing in dynamat. Cost around 20 bucks.... absolutely made the bass accuracy more precise. Took away the plasticky sound and made it more of a traditional thud.
Why dynamat on an enclosure? Obviously on a real wood enclosure this wouldn't do anything... but on plastic.... it makes it much more accoustically neutral. I put a piece inside the enclosure too directly behind the sub.
Worked great.
