Hoverp
So, if you lock the rear end, are in 4x4 , with the torsion front end does the torsion unit provide real 4 wheel drive? I mean if one front wheel were on dry ground and the other front wheel was in the air would the power be split between the 2 or is it truly locked so the power goes to the wheel on the dry ground ? Or does it act more like a limited slip?
Thanks guys
Thanks guys
