GEN 1 RCV Axles on a Daily Driver
RPG
Orange County
Dane- just delete the IWEs. You don't need some super expensive fancy CVs. They won't do anything to help the IWE last.
Stock CV's will overheat with IWE delete kits while on top or mid perch. Make sure to be on bottom perch.
Dane
Dane
Littleton, CO
My CV joint has also broken twice... in addition to the IWEs. Suppose they are related? (as illustrated here: http://www.fordraptorforum.com/f39/dead-cv-axle-something-16497/)
Either way, I'm looking for real world daily driving experience in a IWE delete setup where the front end is always live. Like I said, I both wheel it pretty hard as well as daily drive/tow with it.
---------- Post added at 09:43 AM ---------- Previous post was at 09:41 AM ----------
I'm on mid-perch and would rather not change that as I'm about to add +3 Deavers. RCVs won't overheat?
RPG
Orange County
Give us a call at the shop
scarrjack
The Park, Alberta
[/COLOR]
I am interested in this as well, care to share some info @RPG?
The Mav
Ask anyone with any other truck. Ram, Silverado, Sierra, Ranger, Tacoma, Tundra, etc. No one else uses IWE. Just ford for some dumb reason.
as for the overheating, I would assume that comes from the angle at which the CV joints sit at. After looking at a few pictures I really don't see why mid perch would make any difference. it's not that severe of an angle. unless you have a leaky boot and have lost some grease out of it....
Mid Perch: Angle really isnt that bad at all. Still within very reasonable specs
Top Perch: Definitely can see how this would cause issues. Pretty severe angle here on the CV joints.
RPG
Orange County
When designing or selecting an appropriate CV joint there are 3 factors that are directly linked together. Horsepower / Torque, Angle and Heat Dissipation.
Horsepower / torque is the amount of load or torque being applied.
Example, if you want to increase the horsepower / torque, you will need to either increase heat dissipation or reduce joint angle.
So in regards to the Raptor, if you want to install IWE eliminators (Constant rotation and increased angles), you will need to either decrease angle, move to a colder climate or change out the CV's completely to a different / larger kit.
If you want to increase the horsepower / torque (loading) you need to decrease the joint angle or increase heat dissipation.
Dane
Dane
Littleton, CO
Sooooo, again, would RCVs axles fit that bill and not overheat?
Still waiting for a call back from you guys about a product I'd never heard of - some sort of upgraded IWEs from RCV that aren't a delete. Extremely interested in these, if they really exist. I've never heard of them and can't find any information about them. I spoke to a Cody? Cory? Colby? Couldn't quite tell, my phone was being pissy.
Unless you don't want my money. :boxed:
Yukon Joe
Russellville, AR
Not interested in increasing horse power or torque. Just looking for something to replace the stock system and not be prone to breaking.
@Yukon Joe :baby: :baby: :baby:
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
SILVER
I ordered the IWE Eliminator kit from RCV and when I pulled it apart I fount that the tip of my axle that the nut threads onto snapped completely off. So since I need a new axle I'm thinking RCV but I have all the same questions. Are they really worth the price? Will I be able to run top perch? I do have a Whipple charger as well so I have the increased torque/horsepower issue which is why I snapped the end off the axle and blew the IWE in the first place I guess...
@RPG
