Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Tech Forums > 2011 Ford SVT Raptor Forum (Reply Only)
Ford Super Duty 250 AUX Switches - Raptor?
This is a discussion on Ford Super Duty 250 AUX Switches - Raptor? within the 2011 Ford SVT Raptor Forum (Reply Only) forums, part of the Ford Raptor Tech Forums category!
Are the AUX switches in the Superduty 250 compatible with the Raptor? i.e., are they the same size? I talked ...
Old 06-07-2011, 08:17 AM   #1 (permalink)
Default Ford Super Duty 250 AUX Switches - Raptor?
I talked to a tech at DMH Performance about the electrical cutout question using the AUX switches on the Raptor... he said he heard that some guys have used the switches from the Superduty 250 as they can come "di-pole" for controlling things like a winch... he thought they were the same size. It would be a different color, but would be a cheaper option than getting the control module from Hennesey????
Mark Ducati is offline   Reply With Quote
Old 06-07-2011, 02:34 PM   #2 (permalink)
HoustonRider's Avatar
I've had both trucks and far as I can tell they are the same, even the amp ratings. An electric dipole is a separation of positive and negative charges. I don't know of a winch with a negative charge.
I don't see why you couldn't use the Aux in the Raptor, unless the amp draw were over the amp ratings of the factory switches.
2017 SD 6.7 CCLB Plat Ultimate Dually
AF Baus
2011 SVT Raptor - Tuxedo Black
SDHQ/Vision X/Method Racing/General/SCT
HoustonRider is offline   Reply With Quote
Old 06-08-2011, 04:08 PM   #3 (permalink)
The AUX switch in the raptor is a monopole simple on/off switch... it would work if it were dipole with power in both directions to open/close the valve.... but its not.
So, trying to use the switch as is, will run continuous power to open it and burn out the motor if left in the on position... so turn it off, but then the valve stays open with no way to close it.
Raptor sees work duty today. Madcowranch Ford SVT Raptor General Discussions [GEN 1] 13 04-07-2011 01:01 AM
Upfittert switches ant the Ford racing light bar with KC lights baja100 Ford Raptor Problems and Questions Forum 5 12-04-2010 03:33 PM
2011 Ford Raptor SVT / Super Crew Ordering? Shaggy Prospective Raptor Owners 23 11-11-2010 08:29 PM
