Power steering pump went bad
Trapcity
Maryland
Hello famliy... My power steering pump went out in my baby :( I can steer the truck while I'm driving but at a dead stop its hard as crap to turn my steering wheel. I attempted to do this job myself last saturday, got the pulley off and removed the return line under the pump. But when i tried to get to the 2 bolts behind the pump the oil filter holder ( not sure what its called where the oil filter screws on to) was in the way.. So me very upset had to put everything back together because the night was coming.... Does anyone have a DIY write up to help me get this old pump off ? I have a 2012 6.2 all help is greatly appreciated... I don't have any pics i should of snapped some smh.
Trapcity
Trapcity
Maryland
Thank you @yukonJoe i bought the book on f150s but doesn't help with the raptor smh, i don't want to take this to ford. And I'm sure it isn't under the power train warranty
upscrazy8
tennessee
Thx @Yukon Joe @OrangeAddict.
@Trapcity. My best advice is take to dealer it should be covered, no problem and then warrantied by ford again. If your hard on the wheel this will happen again.and again. And again. And again
I'm no good at write ups but will try and give some of what I remember , also I talked my copilot/brother/head mechanic into it. Hehe.
Take skid plate off and start wrenching. Lol. It seems there are 3 bolts holding it on and would need a couple three extensions from underneath and maybe climbing over into the engine compartment to get from above it. Very uncomfortable and awkward without a lift. Patience is your friend. It was a messy job. I will talk with him and ask if for any other pointers. GL if you DIY. If you get stealership to do it, go there first for diagnosis and approval and then if not in stock have em make appt for when it comes in and should be done that day, reminder to flush completely real well and check out steering rack while there. Hope some of this helps.
Trapcity
Trapcity
Maryland
@upscrazy8 ok will do thanks so much, I have 38 grand on the ODO but i will take it by ford if its under the power train warranty. I actually got to the pump but couldn't get to the back bolts... Could the rack be gone as well? I hope this is all under warranty...
justcozz
Madison, AL
My dealer wouldn't cover the PS pump at 36,200 miles. I actually had less than that but they told me to come back the next day when they turned me away again. I also have the extended powertrain warranty, which didn't help.
The power steering pump is actually a pretty simple job. You got the easy part done if you had 2 of the bolts and the hoses off. You really want to change this before you drive too much more since whatever crap is in the fluid is now flowing through your system including the rack. You don't want to change the rack, trust me!
Proceed as before but when you get to the hard bolts you'll want to put together a couple of extensions and a universal adapter for your socket. This will allow you to lay on your back and easily reach the bolts. If you have a friend that can blindly help hold the socket on, from the top, as you're turning it sure helps. The last 2 bolts are a pain in the ass to reach but if you use the extensions and universal you can get right on them.
I didn't remove the wheels to do mine though it may give you some extra room. You will want to put the tuck on jack stands for the flush if you can. After you get the pump swapped, you'll want to remove the reservoir and flush it out completely with some brake cleaner. You need to get as much of the residual metal shavings and crap out of the system as possible before you flush it back through the system.
Once you've cleaned everything and reinstalled all components you want to flush the entire system. The PS pump on our trucks is really strong as far as the amount of fluid it pumps. This part is definitely a 2 man job so find a friend. There are tons of opinions on how to best accomplish this so I'll just give you the easiest from my perspective.
- Truck on jack stands so both front wheels are off the ground.
- Remove the return line from the reservoir and angle towards a bucket.
- Fully fill the reservoir and turn on the key. You'll want someone stationed at the reservoir with plenty of fluid ready to pour since the pump will pull it through the system quickly.
- Turn the wheels at least 10 times fully left to right and back to left. This will take several quarts of fluid. You'll also probably need to turn the truck off several times during the process. If you hear any screeching or the guy can't keep the reservoir full, kill the engine immediately. Like I said, the pump pulls a lot of fluid very quickly. You want to make sure you're flushing all fluid from the system to include the rack.
- Kill the engine once you're getting nice clean fluid and you've turned 10 times each way.
- Reinstall the return hose, and inspect everything again
- Clean up your substantial mess since you were clumsy with the bucket and fluid is now everywhere.
- Fully service the reservoir and turn the truck back on. Turn the wheel 10 more times in each direction.
- Turn off truck and reinspect for leaks.
- Top off reservoir if it needs it now that everything was pressurized and flowing.
That method should get you moving in the right direction. The task of changing the PS pump is daily simple and straightforward but scary if you haven't done it before. If nothing else, be glad you aren't doing it on the trail somewhere. If you've got any questions as you go feel free to hit me up. I'm mostly bored today.
Pro-tip: Don't hold the wheel so hard in the future. If you are white knuckling the steering wheel, you'll cause the pressure spikes that kill your pump.
Trapcity
Trapcity
Maryland
@justcozz, Thank you so much brother i will re attempt this saturday... I haven't driven my truck since sunday. I will get some help and finish this job, cause i miss my truck! I will reach out to you if i have anymore questions. Thank you once again this is greatly appreciated
