Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Front tire wear problems
This is a discussion on Front tire wear problems within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Hey guys i got my truck at 9,000 miles and then immediately mid perched the truck and then had it ...
Old 04-17-2014, 01:57 PM   #1 (permalink)
McDowell's Avatar
Default Front tire wear problems
Hey guys i got my truck at 9,000 miles and then immediately mid perched the truck and then had it aligned at the dealership. I now have 15000 miles and i looked at my front tires and the inside of them are very choppy and wavy with uneven wear. I grabbed the tires to check my ball joints and nothing is wrong with them no play in my front end. So is this an alignment problem? ford is setting up an appointment with me but said i wont get another free alignment and i haven't done anything to my truck since then so would this not be their fault if it is an alignment problem?
any help would be appreciated
Originally Posted by RDFTS View Post
My balls are small.
This is America. We drink beer, carry guns, say merry christmas, and speak English. If you don't like it get the hell out.
McDowell is offline   Reply With Quote
Old 04-17-2014, 06:32 PM   #2 (permalink)
WRCRaptor's Avatar
I have the same issue, it did it on low perch with stock tire and seems to be happening faster mid perch / G.Y. Duratracs. Allinment is within stock settings also all bushings and tie rods appear to be good, Maybe aftermarket upper control arms would help but not sure on that one.
WRCRaptor is offline   Reply With Quote
Old 04-17-2014, 07:09 PM   #3 (permalink)
Red's Avatar
Red
If you go mid perch you do need an alignment.
2013 White SCREW...K&N CAI, Magnaflow, 10% Tint, hefty fab skid, whelens with WSI mounts, WSI HD Springs, spray in liner,TMX Skid Plate, 30"LED, Mid Perch, Bed Rack
Red is offline   Reply With Quote
Old 04-17-2014, 07:33 PM   #4 (permalink)
AZEngineer's Avatar
Do you have aftermarket wheels? If yes are they lug centric?
AZEngineer is offline   Reply With Quote
Old 04-17-2014, 11:21 PM   #5 (permalink)
WRCRaptor's Avatar
Sorry I did not state that alignment was done at mid perch change and then rechecked after 6,000 and a few off road runs one of which was snoball and is within factory specs. In most cases cupping inside of front tires can be caused by to much camber but my truck is below the max factory setting.
I think an aftermarket upper control arm may help in terms of alignment and smother movement but I may be wrong on this. I dont care that much since I put 26,000 miles on the stock tires and another 20,000 out if the duratracs and each set still had more life in them when I sold them. The only thing that bugs me is that they get loud as they cup.
Old 04-18-2014, 07:01 AM   #6 (permalink)
McDowell's Avatar
I have the svt beadlocks
Sent from my iPhone
My balls are small.
Old 04-18-2014, 10:58 AM   #7 (permalink)
155mm's Avatar
Maybe this is why the 6.2 calls for rotations every 7,500 miles, and the Raptor requires tire rotations every 5,000 miles.
155mm is offline   Reply With Quote
Old 04-18-2014, 11:13 AM   #8 (permalink)
McDowell's Avatar
Idk becoming a nightmare
Sent from my iPhone
My balls are small.
Old 04-18-2014, 11:42 AM   #9 (permalink)
WRCRaptor's Avatar
5k rotation helps for sure, but once they are cupped they never recover
Old 04-18-2014, 03:54 PM   #10 (permalink)
McDowell's Avatar
Why are they doing this
Sent from my iPhone
My balls are small.
Tags
alignment, tires
Torsen front axle problems ! anyone else ??? ITSALLGOOD Ford Raptor Problems and Questions Forum 302 05-16-2015 10:52 AM
BFG tire wear? warrior Ford Raptor Wheels & Tires Forum [GEN 1] 63 12-02-2013 10:52 PM
If you havin' girl problems I feel bad for you son. I got 99 problems... Humvee21 Other Vehicles 55 11-21-2011 02:08 PM
Common Issues/Wear/Problems? LandSeaAir New Member Check-In 9 12-08-2010 05:08 PM
How to read tire wear SOCOMech Ford Raptor Maintenance Forum 1 03-16-2010 04:32 AM
