Maybe this will help?
TSB
13-6-8 6R80 TRANSMISSION HIGH GEAR ENGAGEMENT FROM A STOP - VEHICLES BUILT ON OR BEFORE 4/8/2013
Publication Date: June 7, 2013
FORD: 2011-2014 Mustang
2011-2013 F-150
2012-2013 Expedition
LINCOLN: 2012-2013 Navigator
The article supersedes TSB 13-4-9 to update the vehicle model years.
ISSUE:
Some 2011-2014 Mustang, 2011-2013 F-150, 2012-2013 Expedition and Navigator vehicles equipped with a 6R80 transmission and built on or before 4/8/2013 may exhibit a transmission engagement in 5th gear when starting. The wrench indictor and/or the seat belt minder may be illuminated, the speedometer reads zero and the odometer displays dashes while driving. Symptoms may clear after an ignition key cycle. Diagnostics trouble codes (DTCs) P0720 and P0722 may or may not be stored in the powertrain control module.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the molded leadframe on the main control assembly. Refer to Workshop Manual (WSM), Section 307-01 Shift Solenoids.
NOTE: REPLACEMENT OF SHIFT SOLENOIDS ARE NOT REQUIRED FOR THIS PROCEDURE.
PART NUMBER PART NAME
AL3Z-7G276-A Molded Leadframe
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
130608A 2011-2013 F-150, 2012-2013 Expedition And Navigator 6R80 Transmission: Check DTCs And Replace The Molded Leadframe (Do Not Use With Any Other Labor Operations) 2.1 Hrs.
130608A 2011-2014 Mustang 6R80 Transmission: Check DTCs And Replace The Molded Leadframe (Do Not Use With Any Other Labor Operations) 2.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
7G276 d4
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2013 Ford Motor Company
