.5" Wheel Spacers - Opinions?
JetDriver480
JetDriver480
For what it's worth Discount Tire today said they will work with Bolt on Spacers but not with simple spacers that simply slide over the lugs.
CJT123
These don't seem to have a lip on them to hold the hub centered. I wouldn't use these.
This is the "right" way to make spacers:
Which spacers/adapters are you referring to that don't have a lip on them to hold the hub centered?
NJSP117
New Jersey
I have a set of 1 1/2" spacers awaiting for the arrival of my Gen2, I think they will poke the beadlocks out just where I want them, can't wait
The 1 1/2 spacers won't work with the beadlocks without trimming the lugs by about 2mm. The studs are 1.5 inches long, but have a little nub on the end and the beadlocks will not sit flush. The non beadlocks have little hollow spaces that the lug tips sit in. I tried it...
You can trim those tips off and they'll work, or grind them down.
