Timbren has a solution for rear suspension sag!
Sasha4
1600lbs of payload
I cut my timbrens in half seems to work fine
This whole thread is like dejavu. I went through all of this with my FJ Cruiser back in 2012 with these. and like the OP deducted they suck for off road and ended like you- cutting them in half. These work if the axle stays in contact the entire time otherwise its like hitting a much lower bump stop every time you touch them.
dsiggi
Detroit
3 3/4 inch lower with load
Started at 8 3/4 went down to 5 1/45ec523568675d92164ab0bd08f1700ba.jpg7e9c0d7eddcbd581bd07bc5714ed84e3.jpga906ed0688ba3afa0be12ad19f28a407.jpgfb57ecf3afd3e1250e354497dfba59ff.jpg
So it looks like this keeps the truck level. Did you do this so you can leave them on all the time and not remove them for only when you need the extra payload?
Nerdles1
Yes that is exactly what I wanted to achieve. I pick up a load every week but didn’t want to have to take the timbrens off. Before I cut them in half, the ride was a little too rough at times for my taste others may disagree. I primarily like them there because it may help me to not damage my suspension when I get the overloaded payload in the back. It is not a perfect solution but cheap enough to try.
Nerdles1
Same height drop while pulling my boat. Boat weighs around 10000lbs 35ft long on a trip axle trailer67efba3c1296120b1686a3f28c7b3e2e.jpgdb2f53ef4f3a47c92d46fcb69a724b67.jpg
I wouldn’t go trekking any far distances unless had to but for what I do it’s not a prob
TXRaptor
Yikes! You know the SuperCrew Raptors are only rated to pull 8,000 lbs, right?
https://www.caranddriver.com/ford/f-150-raptor/specs
My Gen 1 SuperCab is even worse at 6,000 lbs. My boat was right at 4,000 lbs dry weight, so I know I was under 6K even when it was loaded with 50 gallons of gas and toys, etc.
Nerdles1
Yep I’m aware
I only have to go about 5 miles 3 or 4 times a year pulling it.
velox
Hey guys I am new to the board and as a 2018 Raptor owner. Loving the truck so far but never had any issues with towing as I am used to the vehicles with airbag suspension. I've been investigating these Timbren's, does anyone have any success with them towing any larger 23' wakesurf boats and any pictures of what the truck looks like? Also, have we discovered anything else without a custom fab?
Thanks for everyone's help with this!
TXRaptor
I installed a set of SuperSprings on top of the leafs for my Gen 1 to handle my boat and 7x12 trailer.
https://www.supersprings.com/shop/SSA28/
I towed a 23" Yamaha Jet Boat with little to no sagging. The SuperSprings website does not list anything for the Raptor, but I had mine from a previous F150 and they worked fine. (I am pretty sure mine are the SSA5s) I sold my boat last year, but I will check to see if I can find any pictures of the stance when towing.
I am still debating if I will transfer the SuperSprings from my Gen 1 to my Gen 2.
TXRaptor
Gen 1 Shorty towing Yahama 23" Jetboat
I found three pictures of my Gen 1 shorty pulling my 23" Yahama Jet boat. The boat weighed 3800 lbs empty and about 4400+ lbs when loaded with 50 gallons of gas and toys, etc.
I have the SuperSprings on my truck in the pictures and you can see the sag is very minimal. My truck is sitting at the mid-perch on the front.
I know my stock Gen 2 would sag like crazy with the same load...
georgesr
Oklahoma City area
Timbren didn't want me cutting the stops as had somthing to do with the integrety of the material. so now that they sent me the 4.5 inch versions I have three to pick from.
the 6 inch ones for really heavy loads
the 4.5 one for every day driving and light loads
and the OEM ones for offroading
now that I have changed them several times I can do it in about 5 min I even carry a jack and the different stops with me.
69283d130fd752dc43d43a731182f886.jpgedc10204ce0f65beb39360ae4cad2bf9.jpg16efbf139036e63f10defe220c7576a8.jpg
1600lbs of payload
