Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford Raptor Suspension Discussion and Modifications Forum [GEN 2]
Deavers for the new Raptor
This is a discussion on Deavers for the new Raptor within the Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by WhatExit? +1 inch of ground clearance gained. Approach and departure angles almost no change. Sidewall flex ditto. ...
Like Tree73Likes
Old 08-10-2017, 05:14 PM   #71 (permalink)
crash457's Avatar
That Escalated Quickly...
37's are all about looks and being different and the added unsprung weight, cost and impact they have on the suspension and truck far outweigh any benefits they might have.
1+ makes a difference. Ask any woman...
Also still more benefit than any CAI or catback exhaust...
2017 Ruby Red SCREW 802A-Ordered 8/3, Built 10/14, Released from Factory 12/12, Accepted by Shipping Company 12/27, Delivered 1/19
crash457 is offline   Reply With Quote
Old 08-11-2017, 06:04 PM   #72 (permalink)
CUSTOMWHEELS4U's Avatar
OE tire weighs 65lbs and 37 weighs 70lbs.
OE wheel weighs 32lb
Method Roost wheels weigh 25lbs
Fuel Anza weighs 25lbs
RRW Wheel (coming soon) weighs 22lbs
A 37" tire with any of these wheels is less unsprung weight than the stock cast wheel with the OE 315/70R17. Even more so if you have the heavy beadlocks. So if unsprung weight is a concern, you're ok with the right wheel. 37's also make bumps and dips seem/feel smaller than the 315/70R17.
CUSTOMWHEELS4U is offline   Reply With Quote
Old 08-11-2017, 10:57 PM   #73 (permalink)
Here's a progression of my '17:
Stock (2 pics)
Stock + 250lb camper shell
Deaver 3s + Shell + 100bs of stuff + SVC CAS +1.5" front (2 pics)
vr4henry is offline   Reply With Quote
Old 08-12-2017, 12:14 PM   #74 (permalink)
Junior Member
Why is everyone going with +3's over +2's??
Im new to this market, what is the differences between the two setups??
Forgiven is offline   Reply With Quote
Old 08-12-2017, 12:19 PM   #75 (permalink)
My understanding is that the +2 is pretty much the same height/load as stock. So +3 or +4 if you plan to lift the front or carry more load full time.
ovrlnd is offline   Reply With Quote
Old 08-12-2017, 06:29 PM   #76 (permalink)
Junior Member
What will the new RRW wheel look like?
Are the RRW wheels quality? And do they have to be re-drilled like some of the other 2017 raptor owners had to do?
Old 08-13-2017, 01:53 AM   #77 (permalink)
Peeps are doing plus 3" Deaver's with RPG shackles because the RPG shackles are longer and actually lower the truck 1" and they also add 1" of travel. So if you used plus 2 with RPG shackles you'd be an inch lower.
MajorAR likes this.
Nimrod is offline   Reply With Quote
Old 08-14-2017, 11:13 AM   #78 (permalink)
It's the RR2. The load rating is less than Method but on par with most half ton wheels. 2100lbs. They will not be re-drills. They are in transit in the true 6x135 pattern with a 87mm bore.
Old 08-14-2017, 09:14 PM   #79 (permalink)
Add 1" of travel? No where have I found that it does this? Enlighten me
Stickman89 is offline   Reply With Quote
Old 08-14-2017, 11:26 PM   #80 (permalink)
This is off the RPG website and while they don't give a number my friends that have done this have measured an inch more droop. I'm sold on it but you can do your own research.
RPG Shackle Kit, +2″ over stock, with Poly Bushings. Allows leaf springs to have more articulation/droop travel. Will lower ride height 1″.
Deavers crash457 Ford Raptor Suspension Discussion and Modifications Forum [GEN 2] 1 02-15-2017 04:33 PM
Deavers vince7870 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 4 10-08-2014 06:19 PM
Deavers? AdkRaptor150 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 11 06-11-2013 11:11 PM
Deavers Maxx2893 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 12 02-18-2012 04:15 PM
Outlaw Raptor Bump Stops and Deavers Bar Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 3 12-29-2011 06:49 PM
