Another oil leak.....
shapiroeric
Longmeadow, MA
Almost a year old.....23K miles......spouted another leak....got the oil changed last week and the shop said it was leaking oil from the upper pan. Very slow. Honestly didn’t want to believe it and he said give it a week or two and bring it to the dealer. Anyways today coming out of work noticed the dreaded spot.....
Original leak about a year ago was fixed with a new pan and seal as so many others had as well. Off to the dealer on the 19th (first loaner avail) and will update. Frustrating
k-rub
Tucson, AZ
When you got it done the first time did they say how they went about repairing it?
When I got mine done they said they drained the oil, removed the pan, let the truck sit overnight to drain everything, cleaned the surface, added the gasket/sealant, installed the pan, let it sit overnight again to dry, then added oil and test drove it.
I'm at 22k with some hard offroad miles and it hasn't come back.
man that’s disheartening. I hope you get it fixed right this time.
Booth9999
Idyllwild
4800 just started leaking. What should I do I just paid for royal purple oil, should I just run it until next oil change at like 9-10k? Or should I get it in asap to document it and have them put back in new royal purple?
Jasoncor
Well royal purple is just a marketing gimmick imo. I would get it fixed asap
Ruger
Northern Nevada
If you were bleeding you'd address the problem, and motor oil is an engine's lifeblood.
That it needs to be fixed ASAP is so obvious that it doesn't even qualify as a no-brainer.
shapiroeric
shapiroeric
Longmeadow, MA
That's how mine was fixed......my shop told me the leak was coming from the upper oil pan, not the lower.....the upper was not leaking last year and thus not fixed.....not sure how many others have had an upper issue.....most if not all the problems posted have been with the bigger lower pan.....
shapiroeric
shapiroeric
Longmeadow, MA
Letting them sit around in driveways, garages or dealer parking lots is Raptor abuse. We must end the cruelty of Raptor abuse.
--smurfslayer
Chairman and CEO
Society for the Prevention of Cruelty to Raptors
#BlackRaptorsMatter
#AllRaptorsMatter
:biggrin:
Absolutely!!
