Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 2 (2017+) Ford F-150 Raptor Forums > Ford F-150 Raptor General Discussions [GEN 2]
4 Auto Issue
This is a discussion on 4 Auto Issue within the Ford F-150 Raptor General Discussions [GEN 2] forums, part of the GEN 2 (2017+) Ford F-150 Raptor Forums category!
Originally Posted by Jeff-Ohio Thanks to all for your help. I am dropping it off again tomorrow for a more ...
Like Tree5Likes
Old 01-19-2017, 04:01 PM   #11 (permalink)
u0104940's Avatar
Originally Posted by Jeff-Ohio View Post
Thanks to all for your help. I am dropping it off again tomorrow for a more serious issue (truck doesn't shift right and sort of surges while trying to maintain a steady speed), so I will have them look at the 4 Auto issue. Aside from loud clunks, I am guessing they will tell me the noise I am hearing in 4 Auto is normal, but I didn't hear it at all on a 2017 Limited that I drove with the 10-speed transmission. I will keep everybody posted on what I find out. They just had my truck for 8 days with respect to the surging issue and thought it was due to a bad spark plug in cylinder #6 (it threw a misfire code for cylinder 6), but that apparently wasn't the issue because I am still having the same problem. I love the truck, but just want it to run right.
Sorry to hear abut that, best to get it fixed right. This also tells me to take a test drive while at the dealership picking up my truck this weekend instead of just driving it straight home.
pughde likes this.
2017 OW SCREW, 802a. 10/27 Build. Took Delivery 1/29. Dealer has had it since 2/6 for Tran Issue.
2011 OW SCREW, Loaded - Still have it thank goodness
u0104940 is offline   Reply With Quote
Old 01-19-2017, 07:54 PM   #12 (permalink)
I hate reaching out and asking these questions, but I'm not sure if I have an issue with the 4 Auto on my 2017 Raptor or not. When you put your truck in 4 Auto and hit the gas, do you hear a swooshing noise, or something that sounds like "Shshshshshshshshshsh"? It isn't overly loud, but it is obviously drawing my attention. It goes away when I take my foot off the gas. I definitely do not hear the same noise while hitting the gas in to 2 High.
I put my truck into weather mode today while a light snow was falling. I hear the same sound you are describing. I don't know what it is. I only have a couple hundred miles on the truck as well.
theOracle13 is offline   Reply With Quote
Old 05-22-2017, 07:00 PM   #13 (permalink)
Junior Member
Has anyone found a resolution to this issue? I'm having the same issues on my Gen 2 Raptor with 4A and the noise...
pughde likes this.
gocloud is offline   Reply With Quote
Old 05-23-2017, 04:51 PM   #14 (permalink)
I still hear the same noise. I am beginning to think it is somewhat normal. 4A on this truck is definitely not as smooth and seamless as an Acura MDX, etc.... My 2011 Armada 4A mode even seems much more refined to the degree that you can flip the switch between 2H and 4A and I wouldn't be able to tell a difference, but that definitely isn't the case with the Raptor due to the noise, a mild binding feel when accelerating in a straight line, and a mild tug on the steering wheel when coming out of a turn as the system starts engaging the front wheels.
Jeff-Ohio is offline   Reply With Quote
Old 05-23-2017, 05:11 PM   #15 (permalink)
dlbb's Avatar
just a lil info. i only had the raptor a few days. but on the test drive i did put it in to 4a. sale's guy didn't know it could be used on dry roads lol. i noticed no difference then the 4a in my 14 lariat heavy duty, aside from the power of the truck. the sound of the front engaging and disengaging is only noticeable with the radio off. i can definitely feel the pull and feed back in the steering wheel. but so far seams the same as my 14. i will agreee the 4a isn't as refined as the acura mdx. but the mdx is a front primary with rear for traction.
edit i have actually drove the new truck almost 500 miles since last friday @12pm.
dlbb is offline   Reply With Quote
Old 05-24-2017, 03:10 AM   #16 (permalink)
Finder of Raptors
I recommend turning the radio up louder. Should solve the noise problem.
Speedemon likes this.
photoneffect is offline   Reply With Quote
Old 02-19-2018, 05:32 PM   #17 (permalink)
Junior Member
I realize this is an older thread, but thought I'd chime in.
11K miles on my 2017 Raptor, and I too notice a whining metal-on-metal chains dragging on the ground type of noise when the Raptor is in 4A. 2H, it's gone.
I hear it only while accelerating and when power is going to all four wheels. I hear it most between 30-50 mph, probably because faster than that the road noise starts to drown it out.
Benihana is offline   Reply With Quote
Old 02-19-2018, 06:06 PM   #18 (permalink)
kandewinn's Avatar
mines in 4a 85% of the time (Winter Michigan), have never heard any noises from my 4a. Leave it in 2wd and get it to dealer.
kandewinn is offline   Reply With Quote
Old 02-20-2018, 01:15 PM   #19 (permalink)
rtmozingo's Avatar
Sounds like IWE problems guys. Get them checked quick.
Don't shift drivetrain (or change driving modes) unless your foot is off the pedal and you don't have wheel slippage.
rtmozingo is offline   Reply With Quote
Old 02-21-2018, 01:52 AM   #20 (permalink)
Junior Member
I have done all my shifts so far with the car in motion, but without any acceleration or braking. Foot off both pedals, car rolling forward on flat ground.
I contacted my local dealership to have them check it out, I go to them this coming Monday. I'll keep y'all posted! In the meantime, I'm driving the truck in 2H only.
I also got to test drive my buddy's 2015 F150 Lariat. He has the 2.7L engine and 6 speed transmission. I toggled it between 2H and 4A and noticed no difference in sounds on his.
Tags
4 auto, differential, transfer case, transmission
Auto drive Fee_Fi Ford Raptor Audio/Video/Electronics Forum [GEN 2] 16 09-26-2016 07:51 PM
LA Auto Show :( RiverRacerX 2012 Ford SVT Raptor Forum (Reply Only) 11 11-23-2011 11:08 PM
DA auto polishers ??? yomudderputter Ford Raptor Cleaning and Detailing Forum 8 05-26-2011 02:40 AM
