Help With New 2013 SCREW
rokraptor
Hi Guys,
I just picked up a new 2013 SCREW. I've only owned it for a week. It's awesome!!!
My question is will 17" Method Standards with 35" Toyo MT's fit my rig without rubbing?
pat'sRAPTOR
Everywhere
Yea you'll be fine no rubbing at all I have the method standards and I run 35's just fine. When I had my 37" Toyos on I had to do trimming due to rubbing that's the only time you'll need to trim anything is wen you go bigger than 35's
R
rokraptor
Thanks for your reply guys. I guess my question more specifically is that my Screw is on the stock perch setting. So will 35" TOYO MT's fit on 17" Methods without rubbing if I've got stock suspension and Im on the stock perch setting?
MotuMute
Dallas, TX
What kind of offroading are you planning to do? Best if you move to mid perch setting if you plan to offroad. Otherwise ok.
NickPic83
Rockland County NY
yeah at close to full lock with some suspension compression u may rub. if u go mid perch u will be fine plus gain a little extra ground clearance and better ride, not to mention it looks better too.
DesaRaptor
I just put Method NV 17's and Toyo M/T 35x17 on my 2013 SCrew. No issues with rubbing at all. I am at mid perch but I don't suspect you will have any problems.
Fred
Richmond, VA
Try them on the stock perch...if they rub go to the middle...I will reiterate that mid perch will be a better "fit" and the truck rides better as well IMO....
