20X12 Fuel 2-piece wheel fitment?
Swedderburn2
Banned
I just purchased a 2014 Ford Raptor, and am looking at putting these wheels on it and am just wondering if they will fit without adjusting the suspension or anything. I was told by a Vendor that they would NOT fit, but i wanted to ask people on here.. Here they are:
20x12 Fuel 2 Piece Driller Black D25620209847
Toyo Open Country M/T 35X12.50-20
PLEASE let me know if these wheel/tire combination will fit on my truck without having to lift it.
Magnum PI
Not sure I have 20x9 with 35 Mickie Thompson on mid perch. No problems or rubbing. If a forum vendor told you they won't fit. There must be a reason. Check offsets that might work.
Raptor Embroidery
Scottsboro, Alabama
Don't go up to 20's. Max you should ever do is 18's. 20's don't belong on a raptor unless you have 37's. Also don't go past 0mm offset. I actually have metric sized toyos on 18's. The 315/70r18 toyos translate to a 36x13 tire. Fills the wheel well much better. The wheels are method mesh 18x9's.
NickPic83
Rockland County NY
raptor embroidery is right. 0 offset is as far as u should go.
are u planning on ever offroading your truck. if so dont go any bigger than a 18" wheel on a 35
ittybittyfds
Western, MD
0 offset is as far as u should go. [/QUOTE said:
Can you clarify what this means?
I'm looking at 18x9 wheels that have a +30 offset. I'm confused on what negative and positive offset means.
so when I see comments that say don't go past a 0 offset
I read the offset thread but I just don't get it.
I know the methods and Fuels have a 0 offset but I don't want those wheels however I do want the wheels to be pushed out closer to the edge of the wells.
Orionkhan
SoCal
Check out this sticky: http://www.fordraptorforum.com/f25/wheel-offsets-explained-19376/
