SOCOMech
Famous Raptor
I got a Magnaflow Magnapack put on my truck this morning.....and love it The Magnapack's are 4" around but come in different lengths, they're also a straight through design. Not as harsh and loud as a straight pipe but close. I went with the 14" version which is the body, 20" overall when you include the ends. I was told by Magnaflow that the shorter versions would be louder but, not by much. So I went with this length hoping it wouldn't be obnoxious but, loud when I wanted it to be. It's a 3" in and 3" out and I had the exhaust shop run it as a single 3" all the way back but with a 4" tip. I told them how I wanted the tip placed (slash, angle, how close to the body) and they did a great job with it, I'm very pleased. I'm going to paint the tip in flat black high temp paint, probably all the way up to the muffler too. This tip they put on however doesn't look bad as is.
Sound at first start up is a good "WOPPA" to let you know it's there but it dies down to normal idle, pretty cool. At idle, it carries that deep tone but not too loud, just enough to remind you that you have it. Same with cruising speed, the tone is deeper but very close to stock in terms of noise level. Of course, the noise level rises just a bit as you give it gas and when you drop the hammer, it's show time. Along with the healthy deepness of the rumble, it's a smooth sound as well. It doesn't have the tinging sound associated with Flowmaster or the popping sound of Borla. I've always been a Flowmaster guy but after living on youtube and the F150 forums for the past week and a half, studying sound clips, I like that I went this route. The only time I experienced drone is when you first pull away from a stop and it's right at 2K rpm's in 1st, 2nd and just a tad in 3rd.....other than that, no drone. I would describe this set up as a bit healthier at cruising and idle, and a monster when you punch it. So if you're one of those guys that wants a deep, smooth tone all around but loud and throaty when you want it to be, then I would recommend this muffler.
I bought it off of Summit.com for $76.00 (polished too), exhaust shop installed it and did my tip for $95. So all in all and combined with the shipping for the muffler, I'm in it for about $180. I don't feel the need to wait for a full catback system from someone, the entire thing is just a straight pipe the whole way until you get to the rear axle. I don't see an entire system doing that much more on these, hence why I'm perfectly happy with just the muffler swap.
Here's some pics to hold you over till I get some sound and video.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
