punchinpaper
- Joined
- Mar 13, 2015
- Posts
- 157
- Reaction score
- 189
What is the best way to get hard water spots off the paint? Do you have a recommended product for that?
Thanks @2014RubyRed!
For water spots, wash the truck really good then use a clay bar with Detail Spray.
If that does not get them off, let me know and we talk about Plan B.
-Dan
Great I'll have to check this out. I never had trouble with water spots when I lived in Maine but in Florida it's terrible.Second on using distilled vinegar on glass, takes it right off. I have used it on the paint but I would highly suggest using a super soft cloth as vinegar alone will take off the wax and sealant. DO NOT apply hard pressure when wiping, don't ask how I know. You will need to plan on re-applying wax/sealant immediately afterwards.
A quick search find products that are used to remove water spots.
http://amzn.com/B004BFW0EO
Article here:
Using Vinegar to remove water spots - Auto Geek Online Auto Detailing Forum
Meguiar's Sctratch X 2.O worked great for my hard water spots.What is the best way to get hard water spots off the paint? Do you have a recommended product for that?
How did the clay bar and detail spray work for you? I had serious water spots on my window and I took some hard core distilled white vinegar to it, worked like a charm. Not sure about on the paint though
Sent from my SAMSUNG-SM-G900A using Tapatalk
The issue is how much of the surface area that is covered. Its nearly the entire driver door, front fender, and parts of the hood. The clay bar was removing just a little of the spots and it was not overly effective.
I will try some of these other options when the weather permits.
thanks
