Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exhaust and Cutouts Discussion [GEN 1]
Y-Pipe help needed
This is a discussion on Y-Pipe help needed within the Ford Raptor Exhaust and Cutouts Discussion [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Sponsored By: Stainless Works
Old 01-11-2018, 08:30 PM   #1 (permalink)
raptorpaul's Avatar
Default Y-Pipe help needed
I took a large rock to the factory y pipe on the passenger side just behind the cat. There is a dent but no hole there, however it caused an exhaust leak at the manifold and y pipe flanged connector. I have tried to reposition it with no success and took it to a muffler shop who repositioned and put some sealant on the joint which worked for a couple months. The problem is back just wondering if anyone else has had similar issue or suggestions. I am tempted to cut the flange off and weld on a new one. Or if I buy a new y pipe no cat will it throw CEL? “Of course off road use only” and could I get it shipped to CA?
2013 SCREW Ford Raptor
raptorpaul is offline   Reply With Quote
Old 01-11-2018, 10:16 PM   #2 (permalink)
No cats will cause a CEL, it can be remedied with a tune but will show an O2 readiness fault at emissions time
jpwrx2002 is offline   Reply With Quote
Old 01-11-2018, 10:58 PM   #3 (permalink)
If cheaper to fix do that if not just buy an after market y pipe with no cats and call it a day.
biturbomg is offline   Reply With Quote
Old 01-12-2018, 04:20 PM   #4 (permalink)
Junior Member
I too had a leak and have been looking for after market Y-Pipes with cats for our trucks. I only see ones for long tubes. Are there any after market y-pipes that work with stock manifolds?
Red01Z06 is offline   Reply With Quote
Old 01-12-2018, 11:22 PM   #5 (permalink)
raptorpaul's Avatar
Only one I found was Bassani with no cats. Would have to swap out every two years. “When it drives on the street” for reg.
WTB: OEM Y pipe and resonator lobird91 Want to Buy 0 08-15-2016 11:54 AM
WTB: 2010 Premuffler/ resonator pipe or corsa delete pipe. Ramathorn178 Want to Buy 3 05-20-2016 11:25 AM
WTB SW Y Pipe SlimChaChi Want to Buy 3 08-25-2015 04:08 PM
Is a Resonator delete pipe any different that a straight pipe? LekRap Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 23 02-12-2015 10:46 AM
? on Y pipe spartanraptor Stainless Works 7 06-29-2013 04:12 AM
