Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exterior Modifications Forum [GEN 1]
Glass Fenders, really worth it??
This is a discussion on Glass Fenders, really worth it?? within the Ford Raptor Exterior Modifications Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I want to put Boatec fenders on my truck, but don't know if it's worth it. I want the meaner ...
Like Tree1Likes
Old 08-18-2013, 02:27 AM   #1 (permalink)
Senior Member
Default Glass Fenders, really worth it??
I want to put Boatec fenders on my truck, but don't know if it's worth it. I want the meaner and wider look, but don't want my truck to look like crap. Any suggestions or opinions?
WilsonRaptor is offline   Reply With Quote
Old 08-18-2013, 02:59 AM   #2 (permalink)
Dan06's Avatar
I personally believe they should come with them from Ford. I am currently running stock wheel/tires, mid perch, and glass fenders. Still stuff the tires up far enough on hard landings to rub the upper bracing. Fixing to install some inner fenders, however I'm afraid I'll trash them without going to top perch or 3.0s.
MotuMute likes this.
Dan06 is offline   Reply With Quote
Old 08-18-2013, 07:16 AM   #3 (permalink)
Rookie's Avatar
They're worth it. Especially if running 37s. Personally I'd go with fronts and rears to make it look uniform. Don't care for the fronts and no rears.
Rookie is offline   Reply With Quote
Old 08-18-2013, 10:41 AM   #4 (permalink)
Senior Member
For the rears wouldn't you have to cut up the bed of the truck?
Old 08-18-2013, 10:47 AM   #5 (permalink)
Raptizzle's Avatar
FYT
They are only worth it if you run 37's and plan to stuff the tires on the regular. The fit and finish will never be as good as factory regardless what aftermarket glass you choose.
Raptor Addict is coming out with a new glass setup for the front and rears so I'd recommend waiting to see what he's releasing before making your decision.
Raptizzle is offline   Reply With Quote
Old 08-18-2013, 10:53 AM   #6 (permalink)
IRONMAN's Avatar
Super Moderator
This ^^^^
IRONMAN is offline   Reply With Quote
Old 08-18-2013, 11:16 AM   #7 (permalink)
Senior Member
But for the rears wouldn't you have to cut up the bed of the truck?
Old 08-18-2013, 11:19 AM   #8 (permalink)
Raptizzle's Avatar
FYT
Negative. The glass bedsides are designed to work with the bed.
Old 08-18-2013, 11:30 AM   #9 (permalink)
WSI's Avatar
WSI
You have to drill out all the spot welds out and have to trim slightly around the taillights. You also have to do some trimming inside the rear fender wells . If you do clean work you'll hardly notice it when your done. Most people don't realize we're running rear glass on our OD green rig.
To answer your question, no you don't have to "cut up the bed" but you have to do some cutting on the bed.
WSI does fiberglass installs on Ford Raptors.
WSI is offline   Reply With Quote
Old 08-18-2013, 12:24 PM   #10 (permalink)
Senior Member
How much does a full fiberglass install through y'all usually cost?
Tags
boatec, fenders
Glass fenders lets see them! roostinyfz Ford Raptor Exterior Modifications Forum [GEN 1] 77 09-08-2014 01:51 PM
Another TMXceptional Install - Glass Fenders, NV's, & 37's!! MotuMute Ford Raptor Wheels & Tires Forum [GEN 1] 17 04-09-2013 09:46 AM
Anyone have glass fenders with 35's RLTW Ford Raptor Wheels & Tires Forum [GEN 1] 13 03-16-2013 08:46 PM
Ford Raptor Glass fenders Outlaw Offroad Outlaw Offroad 6 06-22-2011 03:58 PM
