Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Classifieds Forum
Want to Buy
WTB: factory 3rd brake light
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Snowsled" data-source="post: 1227263" data-attributes="member: 25287"><p>You are most likely getting water in the third brake light and shorting the lights. Mine did this to me along with a warning about the hill descent control failing, which is a common thing with this problem.</p><p></p><p>I am removing mine today and taking it apart to see if I can get the leds working again. Then I am going to seal it up really good with silicone. </p><p></p><p>I will post up if I get it working, otherwise just grab the $200 light above, that is $100 less than a new one. Regardless, I would consider some additional waterproofing on install to prevent it from happening again.</p></blockquote><p></p>
[QUOTE="Snowsled, post: 1227263, member: 25287"] You are most likely getting water in the third brake light and shorting the lights. Mine did this to me along with a warning about the hill descent control failing, which is a common thing with this problem. I am removing mine today and taking it apart to see if I can get the leds working again. Then I am going to seal it up really good with silicone. I will post up if I get it working, otherwise just grab the $200 light above, that is $100 less than a new one. Regardless, I would consider some additional waterproofing on install to prevent it from happening again. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
shoracer
Grod760
Jorge Acosta
bubbawoodraptor23
HighNoon
tractorpole
erolivas
forza423
NES431
93,432
56,717
Poseidon02
Forums
Want to Buy
Accept
Learn more…
