Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Audio/Video/Electronics Forum [GEN 2]
Whose truck is this?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BIGDJE" data-source="post: 1399566" data-attributes="member: 29786"><p>not sure what speakers they used but could of used much better amps then those alpine. I did same thing to my truck all in $10K plus phoenix unit</p><p></p><p>did not do the whole floor but doors and back is a must for sound quality of speakers and yes cuts down on road noise floor is little over kill</p><p></p><p>I did rear 12 shallow mounts perfer to keep space under the rear seat vs speakers and the JL 12 shallows still thump was very surprised how great they sound with such little space for a box enclosure</p><p></p><p>so much has changed since back in they day when we used to build "systems"</p><p></p><p>with DSP amp technology I tuned the whole set up on my lab top and can change to 4 tunes with turn of the bass knob which also doubles as tune knob and can adjust the level of mids and highs with the knob also </p><p></p><p>could easy spend 10hrs plus on lab top tuning every speaker, the driver side is time delayed so the sound hits drivers seat same time from left and right feels like you sitting in the middle of the truck and yes it sounds very different then when set to zero delay.</p><p></p><p>each amps has its own tune but the subs which are on the rear amp has a pass through to the front amp so subs are tuned on front amp rear speakers are tuned direct connection to rear amp</p><p></p><p>i turned the center speaker off as i think it sounds better without it</p><p></p><p>[ATTACH=full]130133[/ATTACH]</p><p></p><p>[ATTACH=full]130134[/ATTACH]</p><p></p><p>[ATTACH=full]130135[/ATTACH]</p><p></p><p>[ATTACH=full]130136[/ATTACH]</p></blockquote><p></p>
[QUOTE="BIGDJE, post: 1399566, member: 29786"] not sure what speakers they used but could of used much better amps then those alpine. I did same thing to my truck all in $10K plus phoenix unit did not do the whole floor but doors and back is a must for sound quality of speakers and yes cuts down on road noise floor is little over kill I did rear 12 shallow mounts perfer to keep space under the rear seat vs speakers and the JL 12 shallows still thump was very surprised how great they sound with such little space for a box enclosure so much has changed since back in they day when we used to build "systems" with DSP amp technology I tuned the whole set up on my lab top and can change to 4 tunes with turn of the bass knob which also doubles as tune knob and can adjust the level of mids and highs with the knob also could easy spend 10hrs plus on lab top tuning every speaker, the driver side is time delayed so the sound hits drivers seat same time from left and right feels like you sitting in the middle of the truck and yes it sounds very different then when set to zero delay. each amps has its own tune but the subs which are on the rear amp has a pass through to the front amp so subs are tuned on front amp rear speakers are tuned direct connection to rear amp i turned the center speaker off as i think it sounds better without it [ATTACH=full]130133[/ATTACH] [ATTACH=full]130134[/ATTACH] [ATTACH=full]130135[/ATTACH] [ATTACH=full]130136[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
cmc21
SeasickLI
jm77
WTX
fordfreek
WP13
06z
blazn5667
Mossy 150
BoostedToy
Aurik
RogueClimber
DavidL
8008MD
roger7254
HTXShadow
cfmistry
MurderedOutSVT
bigjava2002
jekyll537
Zeusmotorworks
Mike27t
Drkknght
quattrojim
Oaktree202
shigman
Evil Peaches
Maehr
JCT
AJ36_LeadFootG3
isis
gn2hr
MyBallZachErtz
Hambone
KWB85
XSTNKT
G8R-RPTR
2slo4u
OICNW-Rob
osten100
Shane361
TheGrizz
Jeff Oldham
Reptar854
mleaky
daytona1783
rickysnickers
MotoDad
MORaptor1
... and 29 more.
93,254
56,547
nadz88
Forums
Accept
Learn more…
