Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Transmission Question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Henryrifle" data-source="post: 1085781" data-attributes="member: 22200"><p>I got up early this morning to check out the truck and get going before traffic to play with it some. As mentioned in the original post, the Raptor is very new to me. Today is my 3rd day of ownership.</p><p></p><p>Compared to my F250 diesel, my Raptor also has a rougher idle than I would expect. Not in a big cam lopey kind of way—just rough—like it needs a tune up. I pulled the air filter top off to take a look and the filter was new. I disconnected the wire harness from the MAF sensor and unscrewed it from the air intake housing. Using MAF sensor spray cleaner, I cleaned both the contacts and the exposed wire and reassembled. I checked all fluids while the hood was up and all seemed okay.</p><p></p><p>There is one big difference today than the previous two days. It is almost 60 degrees here in Atlanta today and it has been around 35 in the mornings or below the previous two days.</p><p></p><p>On startup the truck idled much more normally. The roughness and vibration was gone. The most interesting part of the drive this morning is that the hard first to second shifts are gone too. The shift from 1 to 2 is still more noticeable than any other shift like 2nd to 3rd but my F250 was the same.</p><p></p><p>I am not saying that I fixed anything or that it is all good—maybe my truck just runs better in warmer weather. I’ll keep paying attention and am sure there are more cold days coming our way.</p><p></p><p>Thanks,</p><p>Henryrifle</p></blockquote><p></p>
[QUOTE="Henryrifle, post: 1085781, member: 22200"] I got up early this morning to check out the truck and get going before traffic to play with it some. As mentioned in the original post, the Raptor is very new to me. Today is my 3rd day of ownership. Compared to my F250 diesel, my Raptor also has a rougher idle than I would expect. Not in a big cam lopey kind of way—just rough—like it needs a tune up. I pulled the air filter top off to take a look and the filter was new. I disconnected the wire harness from the MAF sensor and unscrewed it from the air intake housing. Using MAF sensor spray cleaner, I cleaned both the contacts and the exposed wire and reassembled. I checked all fluids while the hood was up and all seemed okay. There is one big difference today than the previous two days. It is almost 60 degrees here in Atlanta today and it has been around 35 in the mornings or below the previous two days. On startup the truck idled much more normally. The roughness and vibration was gone. The most interesting part of the drive this morning is that the hard first to second shifts are gone too. The shift from 1 to 2 is still more noticeable than any other shift like 2nd to 3rd but my F250 was the same. I am not saying that I fixed anything or that it is all good—maybe my truck just runs better in warmer weather. I’ll keep paying attention and am sure there are more cold days coming our way. Thanks, Henryrifle [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
cazt51
Morgan
Ruger
thechamp408
WNCHSTR96
MDJAK
REX111
MurderedOutSVT
Brewski
james9
Advcgh
Frogger22
SCAR911
fordrat
Ziggy2023
0341Marine
firemanjoe
MS-Raptor
kpecks
Sonicsunspot
HighwaySentinel
Dbone
j1nino
Wartman
Eisner62
Sano Dano
NorCal Offroad
kponenation
Chupacabras
dillard09
Chewie
downforce137
Johnny149
Russ103
christian26
Reaper308
jwkhd1
deamer
roger7254
NASSTY
RaptorAU
Bozz
Brad_hartpro
Jbultz1
John Liu
flyitaway
jAKe47
futurepr3
cr23raptor1983
redsmoke
... and 19 more.
93,560
56,839
dieslfrkY
Forums
Accept
Learn more…
