Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
Squadron 2 install blowing fuses??????
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Oldfart" data-source="post: 1489581" data-attributes="member: 25546"><p>Well, that is a pretty hot look on that truck!</p><p></p><p> The only reason I asked is I thought possibly all the upfitters were wired similarly, but that they ran lighter fuses in some to match up better for light duty accessories. I know in a normal car or truck it would obviously be a bad idea and smaller circuits have lighter gauge wiring and I wouldn't do it. I never worked on anything with the factory upfitters before and didn't know how they set them up or wired them. I actually already bought a 4 pin relay a few hours ago. I figured if I got lucky and you guys told me the wiring was all heavy gauge I would just return it. I had a feeling the answer would be to do a relay, but I was hoping there was a chance for me to do it the easy way for once.</p><p></p><p>Thanks for the straight advice, like you said, the last thing I want is a freaking fire in my new truck! "(2 X 2.9 ) > 5" will be in my head for a long time! <img src="/styles/default/xenforo/smilies/emotions122.gif" class="smilie" loading="lazy" alt=":emotions122:" title="Emotions122 :emotions122:" data-shortname=":emotions122:" />I had it stuck in my head the rating was for a pair. I guess I should make a thread now complaining about the ****** fuses that Ford puts in the Raptors and how a 5 amp fuse blows when all I did was pull 6 through it.</p></blockquote><p></p>
[QUOTE="Oldfart, post: 1489581, member: 25546"] Well, that is a pretty hot look on that truck! The only reason I asked is I thought possibly all the upfitters were wired similarly, but that they ran lighter fuses in some to match up better for light duty accessories. I know in a normal car or truck it would obviously be a bad idea and smaller circuits have lighter gauge wiring and I wouldn't do it. I never worked on anything with the factory upfitters before and didn't know how they set them up or wired them. I actually already bought a 4 pin relay a few hours ago. I figured if I got lucky and you guys told me the wiring was all heavy gauge I would just return it. I had a feeling the answer would be to do a relay, but I was hoping there was a chance for me to do it the easy way for once. Thanks for the straight advice, like you said, the last thing I want is a freaking fire in my new truck! "(2 X 2.9 ) > 5" will be in my head for a long time! :emotions122:I had it stuck in my head the rating was for a pair. I guess I should make a thread now complaining about the ****** fuses that Ford puts in the Raptors and how a 5 amp fuse blows when all I did was pull 6 through it. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
MidnightSpecial
Maximus007
Pyro3601
RamseyF
tcm glx
bellnghmrider
Psirus7
Shane361
kevo_lo
TAC71
BadWRP
tonythis
OBXRAPTOR17
Frogger22
catinthehat85
weldoid
CleverGirl_
Beinkounter
GCATX
pattmarsons
17baker
wesleywest
rohokieop
jekyll537
Rahptor
kocher93
nicewaptor
RobSpring661
Lupuswins
WhiskeyTangoGTFO
BBLV
Whoops
Drkknght
XSTNKT
Domin0
RCorsa
Old-Raptor-guy
Butterz
taquitos
LibertyDNP
SB88
az_gen3
WTX
NJ2020
cuts
... and 3 more.
93,189
56,469
ngodavid23
Forums
Accept
Learn more…
