Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Rpg bump stop/icon leaf install
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="M_NorthRaptor" data-source="post: 1580993" data-attributes="member: 32012"><p>Leafs and bumps are installed now. I did a majority of the work myself and a couple things came up while doing the process.</p><p>- Speed sensor mounts had to be cut off and ground down smooth to fit strike plates on both sides properly. Nowhere on anything says to cut those off so be aware that they HAVE to be cut off and cleaned up</p><p>- As well as Icons torque specs are not correct other than their u-bolt nuts (40ft.lb-140ft.lb).</p><p>- Noticing both sides, retaining sleeve bolts are rubbing the exhaust at full droop in option 2.</p><p>Over all not a hard hard job just tedious and take your time.</p></blockquote><p></p>
[QUOTE="M_NorthRaptor, post: 1580993, member: 32012"] Leafs and bumps are installed now. I did a majority of the work myself and a couple things came up while doing the process. - Speed sensor mounts had to be cut off and ground down smooth to fit strike plates on both sides properly. Nowhere on anything says to cut those off so be aware that they HAVE to be cut off and cleaned up - As well as Icons torque specs are not correct other than their u-bolt nuts (40ft.lb-140ft.lb). - Noticing both sides, retaining sleeve bolts are rubbing the exhaust at full droop in option 2. Over all not a hard hard job just tedious and take your time. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Rednose
letsgetthisdone
The Doo
WhiskeyTangoGTFO
icecoldak
oliverb
DougDimmadome
shigman
Coyote_695
VJDWashington
RiskTkr
3Dog
stan972
Frogger22
Keshar88
Moebeus
bjorn-dpc
TomDirt
GCATX
k3k0a808
FmaxTurboSi
KMO
nikhsub1
Ifly4vamerica
JBTAC
tcm glx
Sage
julien194b
grillcheeseRaptor
kevo_lo
Sergio212
NASSTY
GEN3LV
Ruger
93,202
56,485
bjorn-dpc
Forums
Accept
Learn more…
