Rhino vs Line-X
AZ SVT
Delta Junction, Alaska
Just in case it has not been mentioned yet.... if you have the tail gate extender make sure they mask the little holes in the bed sides that the extender locks into. Also, after a few weeks I noticed the paint is worn along the bottom of my tail gate where the bed liner is rubbing it. Best fix would be to make sure they spray at least that small strip along the bottom of the tail gate bellow the stock plastic tail gate liner.
linexsa
San Antonio TX
those little plastic pop ins where the bed extender locks into should be removed and reinstalled after the bed is sprayed. Spraying over those plastice pieces always leads to trouble.
SoSmoked
changes his exhaust setup more than his underwear
I initially was going for line x until I found out nobody in my area (40+ square miles) uses the stuff anymore
When I asked why I got the same answer from all the guys
Said line x is out dated when compared to rhinos new material
Said that rhino is constantly r&r ing and line x has had the same shit for 30 years
I was sold and had it done for 350$
So far it still looks sparkling new and hasn't dented tore scratched
linexsa
San Antonio TX
this is a farse. rhino is still using a 2:1 system even though it is sprayed high pressure is still a full polyurethane and not as strong as a polyurethane polyurea hybrid. Alot of Line-X dealers got out when the economy got bad due to high chemical prices. There are plenty of cheaper products out there you can still call a bedliner. Alot of applicators have traded quality for the almighty dollar.
SoSmoked
That may be true
Personally as far as the bed liner goes its not a work truck I simply wanted a nice looking product that sparkles like my truck did
The price was right and I saved the 300$ so I can drop it into other mods
Like my exhaust
Haha
linexsa
San Antonio TX
HAHA i have a customer just like you that changes his exhaust ALL THE TIME! 09 black platinum screw and has changed 6 times and only has 11K miles.
SoSmoked
Ya sounds just like me I'm doin a new setup tomorrow lolol
JP7
Likes Canadian Mudbaths
Calgary, Alberta
I'm wary of polyurea as I've witnessed several faliures when used as a waterproofing product exposed to sun. Below grade or in marine applications it performs well - but in my expoerience it doesn't have a great track record with roofs or protecting walls. Polyurethane is not bad, but deteriorates over time if there is standing water (not an issue if you do the top perch, or floor it regularly).
