Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Interior Forum [GEN 2]
Rear Seat Delete
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="PlainJane" data-source="post: 1555327" data-attributes="member: 32751"><p>One additional idea I have run across is to leave the 1/3 jump seat and make a compartment for the 2/3 area. The Jack and Inverter are under the 1/3 seat and so there is not that much room to be gained. Also the seat backs reduce the noise coming in through the "exhaust flaps" behind the seat. </p><p></p><p>As for removing the seats on a SCAB, its very easy. The seat belts are the hardest part because you need to remove the side trim.</p></blockquote><p></p>
[QUOTE="PlainJane, post: 1555327, member: 32751"] One additional idea I have run across is to leave the 1/3 jump seat and make a compartment for the 2/3 area. The Jack and Inverter are under the 1/3 seat and so there is not that much room to be gained. Also the seat backs reduce the noise coming in through the "exhaust flaps" behind the seat. As for removing the seats on a SCAB, its very easy. The seat belts are the hardest part because you need to remove the side trim. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Pacifico66
Badboy4fun_wa
jAKe47
Don S
Sugawolf Peezie
LayinWatts69
Corsarych
scroper
1BAD454SSv2
greatone99
mattncsu
93,180
56,460
khunter
Forums
Rear Seat Delete
Accept
Learn more…
