Random Dimension Request on BAK Revolver X4S
MAMiller44
Tampa, FL
Curious if anyone who has a BAK Revolver X4S, or I guess the X4 would be exactly the same as well who could check a quick dimension for me?
Question 1: How far up the bed can you roll it until the "roll" is 4" tall?
Question 2: Is it possible to slide it a little bit towards the cab instead of just rolling it if you have a low clearance? Below description of what I'm going for will help this question make sense.
Reason for the question is that I'm wanting to switch from my Retrax + Rhino Rack bar setup due to numerous reasons and I'm looking at going to a Revolver X4S with KB Voodoo cross bars and a Bedslide S. Ideally it would be possible to roll up the X4S underneath the first bar which would only have about 4" clearance. I know it will never clear the second. If that can be done I think this would be the perfect bed setup I've been dreaming of to have a stout, low-profile RTT setup and a very functional bed setup.
SoxFan
Virginia
I have one, to answer your question......About 6" until the cover reaches 4" tall, not even a full rotation. However you can slide it as far as you wanted under the rear-most cross bar then start the "rolling" of the cover if needed.
MAMiller44
MAMiller44
Tampa, FL
Thank you!!
Kperatt09
COLORADO
did you end up pulling the trigger? i am thnking of doing the same thing but with there 6" bars
