Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Power Steering Cooler
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Trick.Raptor" data-source="post: 1308911" data-attributes="member: 16456"><p>With my stock res my PS would whine and moan pretty quickly while off-road and had to be replaced at 33k. It wasn't much better at first when I went with a PSS reservoir tank and cooler. </p><p></p><p>With the PSS res, the fill line was way to low and the bleed valve at the top would still spray fluid! I went from factory fluid to Royal Purple synesthetic PS fluid that helped with the whining and groaning. I experimented with fluid level filling the PSS res almost to the top and that really made a major difference. And I didn't notice any more fluid spray from the bleed valve at the top. To fix that I just put a sock over the res while off-road. It got dirty nothing else did <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>I upgraded the reservoir from PSS to RPG and that was the best combo. The RPG tank was sealed with a drain hose that goes to the ground. No more PS fluid on the engine! As for my PS pump, it now has 63k on with lots of off-road abuse.</p><p></p><p>At Oceano Dunes with tire pressure around 13PSI I never hear the PS pump whine or groan. At first I watched the temps and the fluid never really got hot with no cavitation. Current RP fluid has well over 40k and doing fine.</p><p></p><p>I can't speak for the setup you have it will not help much if you run the stock reservoir tank. You will still get a lot of fluid splashing around inside with cavitation that causes air pockets. That is where the whine and groaning starts.</p></blockquote><p></p>
[QUOTE="Trick.Raptor, post: 1308911, member: 16456"] With my stock res my PS would whine and moan pretty quickly while off-road and had to be replaced at 33k. It wasn't much better at first when I went with a PSS reservoir tank and cooler. With the PSS res, the fill line was way to low and the bleed valve at the top would still spray fluid! I went from factory fluid to Royal Purple synesthetic PS fluid that helped with the whining and groaning. I experimented with fluid level filling the PSS res almost to the top and that really made a major difference. And I didn't notice any more fluid spray from the bleed valve at the top. To fix that I just put a sock over the res while off-road. It got dirty nothing else did :) I upgraded the reservoir from PSS to RPG and that was the best combo. The RPG tank was sealed with a drain hose that goes to the ground. No more PS fluid on the engine! As for my PS pump, it now has 63k on with lots of off-road abuse. At Oceano Dunes with tire pressure around 13PSI I never hear the PS pump whine or groan. At first I watched the temps and the fluid never really got hot with no cavitation. Current RP fluid has well over 40k and doing fine. I can't speak for the setup you have it will not help much if you run the stock reservoir tank. You will still get a lot of fluid splashing around inside with cavitation that causes air pockets. That is where the whine and groaning starts. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Raptor1776
GordoJay
ChipBeck
Angry_4dr
REX111
Hal993
BadWRP
dundon929
Hup
jwkhd1
Nesc204
mleaky
KMO
Wolfie11
nikhsub1
someday
dsg2003mach1
samgen2
cmc21
Helopilot
darkslide750
Latchkey Kid
socal raptor
Northerndino
IIAWAH808
BeepsRaptor
soudaldayoli
FoxNotch
WC114
billyjohnny
8250_RPM
Raptor513
lawtonmc
Dudebrodude
Butterz
Hannibal
CleverGirl_
wvp8011
Hoffer
usnmustanger
GCATX
Five-O Donut Hole
stevenstommyboy1
MagneticScrew
Backcountry Rabbit
bigjerry
NorCal Offroad
whatthetruck
Reptar854
elpechedepeche
... and 44 more.
93,330
56,618
hunter8793
Forums
Accept
Learn more…
