Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Persistent Front End Rattle
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Canuck714" data-source="post: 890156" data-attributes="member: 6707"><p>Just throwing this out there... </p><p>I had an annoying rattle on my 911 C4S that I could not find for weeks. It never happened at start-up, but once up to temp the rattle would start. Goes away under heavy throttle, but pulling into the garage it sounded horrible. After tightening and re tightening everything I could think of, the sound finally went away when I installed Cat delete pipes.... Sure enough, something inside the passenger side cat had come loose and would rattle. Never affected performance, just caused noise.</p></blockquote><p></p>
[QUOTE="Canuck714, post: 890156, member: 6707"] Just throwing this out there... I had an annoying rattle on my 911 C4S that I could not find for weeks. It never happened at start-up, but once up to temp the rattle would start. Goes away under heavy throttle, but pulling into the garage it sounded horrible. After tightening and re tightening everything I could think of, the sound finally went away when I installed Cat delete pipes.... Sure enough, something inside the passenger side cat had come loose and would rattle. Never affected performance, just caused noise. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
dvm
BigA
Mike27t
Lucas_Arg
shigman
pyro_bob
Northerndino
Solboricua18
quattrojim
jpl291
Raptor812
Punkur67
Raptor_arw
93,258
56,552
iAmNotorious
Forums
Accept
Learn more…
