Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Off-Roading Your Raptor
Newbie question about sand dunes
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ACE" data-source="post: 1747600" data-attributes="member: 34041"><p>Traction control needs to be COMPLETELY off. Putting it in Baja mode does not disable the entire system. You will need to press and hold for around 7 seconds the traction control button by the center display. A message on your dash will pop up saying advanced track disabled. 15PSI is good all around for stock tires. Bring a/a few air compressors and some sort of recovery gear. Don’t do quick fast turns when you’re aired down without actual beadlock rings. The ones that come with the truck from the factory are cosmetic only.</p></blockquote><p></p>
[QUOTE="ACE, post: 1747600, member: 34041"] Traction control needs to be COMPLETELY off. Putting it in Baja mode does not disable the entire system. You will need to press and hold for around 7 seconds the traction control button by the center display. A message on your dash will pop up saying advanced track disabled. 15PSI is good all around for stock tires. Bring a/a few air compressors and some sort of recovery gear. Don’t do quick fast turns when you’re aired down without actual beadlock rings. The ones that come with the truck from the factory are cosmetic only. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Shepherd_
rhythmchamber
Dev
EasyDoesIt
Russ103
Littlefx4
Blown00gt
2024RaptorR_NOVA
cswht
RCorsa
Bluto
stevenstommyboy1
5280 Raptor
peavey02
kalel
xgardx
Justbob
CleverGirl_
MotoDad
mprice1234
briangsxr1000
MZRaptor72
SeasickLI
cfmistry
hamster
GOTSVT?
Raptor812
Dnpbakon
FordPerf Addict
awd5906
jdm_sixtwo
bjorn-dpc
-RRRaptor-
Bobby Tucker
RaptorEnjoyoer
MORaptor1
Jason Watson
B boyes
93,224
56,503
DehydratedSurfer
Forums
Accept
Learn more…
