Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
Livernois Motorsports
Livernois First ZL1 in the 9's! Specs and Video
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Livernois Motorsports" data-source="post: 200830" data-attributes="member: 847"><p>See our <a href="http://www.livernoismotorsports.com" target="_blank">website</a> for our <a href="http://www.livernoismotorsports.com/categories/GM%7B47%7DChevrolet/2012-Camaro-ZL1/" target="_blank">ZL1 specific packages</a>. We can also build a package to fit your needs.</p><p></p><p><strong>Specs:</strong></p><p></p><p>Delivered by Rodger’s Chevrolet 4-27-12 (yes, we’ve only had it 2 weeks!)</p><p>2012 ZL1 Auto trans - Full weight with exception of wheels/tires</p><p>100% stock suspension</p><p>Stock trans w/ Livernois specific trans calibration</p><p>Stock catback</p><p>4,295 lbs. with driver</p><p>240 Miles <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p><strong>Mods: </strong></p><p></p><p><a href="http://www.livernoismotorsports.com/categories/GM%7B47%7DCadillac/2009%252d11-CTS%252dV/2009%252d11-CTS%252dV-Engine/2009%252d11-CTS%252dV-Cylinder-Heads/" target="_blank">Livernois Motorsports In-House CNC LSA Cylinder Heads </a></p><p><a href="http://www.livernoismotorsports.com/products/Livernois-Motorsports-L92-Stage-2C-High-Lift-Camshaft.html" target="_blank">Livernois Motorsports Stage 2C High Lift Camshaft</a></p><p>Livernois Motorsports LSA Head Studs (Available soon)</p><p>Livernois Motorsports Exclusive Heat Exchanger (Available soon)</p><p>Livernois Motorsports Solid Supercharger Coupler</p><p>Livernois Motorsports Supercharger Pulley</p><p>Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon)</p><p>Livernois Motorsports Spec’d Injectors</p><p><a href="http://www.livernoismotorsports.com/products/2010-Camaro-Dual-Fuel-Pump-Assembly.html" target="_blank">Livernois Motorsports Dual Fuel Pump Upgrade</a></p><p>Precision Industries Converter Built to Livernois Specs</p><p>Metco Oversize Crank Pulley Ring</p><p>Innovators West Oversize Balancer</p><p>Rotofab/Livernois Cold Air Intake (Available soon)</p><p>Stainless Works Longtube Headers & Connection Pipe</p><p>Hardened Pushrods</p><p>NGK TR6 Spark Plugs</p><p>160 Degree T-Stat</p><p>GM 90mm Throttle Body</p><p>Bogart 17” Wheels w/ Slicks & Skinnies</p><p>Livernois Motorsports Dyno Tune</p><p></p><p><strong>Dyno Results Stock:</strong></p><p></p><p>476 RWHP / 476 RWTQ</p><p></p><p>The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it.</p><p></p><p><strong>Dyno Results Modified:</strong></p><p></p><p>707 RWHP / 680 RWTQ (Roughly 850 crank HP)</p><p></p><p><strong>Note:</strong> Our tuner Dan Millen was at the track with me all day logging each pass and getting more and more aggressive after each pass, so I’m sure the power was quite a bit higher than what we saw on the dyno. </p><p></p><p>Just a little info on Dan, he is a multi-time 10.5 tire world champion who always sets the bar for the class. His car runs 3.7X @ 204 mph in the 1/8 mile! </p><p></p><p>I wouldn’t hesitate to daily drive the ZL1 with these mods (minus the wheels/tires).</p><p></p><p>I do plan on driving the car to Rodger’s Chevrolet for their show/open house tomorrow, then back to Milan on the stock wheels and Mickey Thompson ET Street Radials to see what it will run on 20’s.</p><p></p><p>The first pass off the trailer today, the car went 10.14 @ 138 MPH. Many of my launches were from just above idle and it was like a bracket car with several 10.0X-10.1X passes @ 138-141 MPH, and FINALLY on the last pass 9.87 @ 142 MPH!! Dan got pretty aggressive with the tune and told me to leave as hard as I could off the converter. We WERE going 9’s on this pass! I did the burnout, staged, then focused… not worrying about my reaction time (it was horrible as you can see), put it on the converter until it felt like it was going to roll forward and let it rip. I knew at the end of the track it was a good pass when I saw 145 mph on the heads up display. </p><p></p><p>We are also currently working with PSI Superchargers to improve the factory blower. Dan runs a PSI screw blower on his 3-Second 200+ MPH 1/8 mile race car. </p><p></p><p><strong>Huge Thanks to:</strong></p><p>GM for building an awesome car, Rodger’s Chevrolet, Milan Dragway for the great track, Innovators West, Metco, Mickey Thompson Tires, Precision Industries, Rotofab, Stainless Works… and the technicians at Livernois Motorsports!!!!!!</p><p></p><p><strong>Vehicle Transport Services:</strong></p><p><strong></strong></p><p></p><p>We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules.</p><p></p><p>We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that your car will make it to our location and back to you safely, and with much more power than it arrived with!</p><p></p><p>Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer.</p><p></p><p>All cars are stored safely in doors before and after work is performed.</p><p></p><p>Please call 313-561-5500 or email <a href="mailto:info@livernoismotorsports.com">info@livernoismotorsports.com</a> for information and pricing.</p><p></p><p>[YT]fx-Rxh2BlPs[/YT]</p><p></p><p>Thank you</p><p></p><p>Regards,</p><p></p><p>Rick LeBlanc</p><p>Livernois Motorsports</p></blockquote><p></p>
[QUOTE="Livernois Motorsports, post: 200830, member: 847"] See our [URL="http://www.livernoismotorsports.com"]website[/URL] for our [URL="http://www.livernoismotorsports.com/categories/GM%7B47%7DChevrolet/2012-Camaro-ZL1/"]ZL1 specific packages[/URL]. We can also build a package to fit your needs. [B]Specs:[/B] Delivered by Rodger’s Chevrolet 4-27-12 (yes, we’ve only had it 2 weeks!) 2012 ZL1 Auto trans - Full weight with exception of wheels/tires 100% stock suspension Stock trans w/ Livernois specific trans calibration Stock catback 4,295 lbs. with driver 240 Miles :) [B]Mods: [/B] [URL="http://www.livernoismotorsports.com/categories/GM%7B47%7DCadillac/2009%252d11-CTS%252dV/2009%252d11-CTS%252dV-Engine/2009%252d11-CTS%252dV-Cylinder-Heads/"]Livernois Motorsports In-House CNC LSA Cylinder Heads [/URL] [URL="http://www.livernoismotorsports.com/products/Livernois-Motorsports-L92-Stage-2C-High-Lift-Camshaft.html"]Livernois Motorsports Stage 2C High Lift Camshaft[/URL] Livernois Motorsports LSA Head Studs (Available soon) Livernois Motorsports Exclusive Heat Exchanger (Available soon) Livernois Motorsports Solid Supercharger Coupler Livernois Motorsports Supercharger Pulley Livernois Motorsports Exclusive Steel Idler Relocation Bracket w/ Metco Pulleys (Available soon) Livernois Motorsports Spec’d Injectors [URL="http://www.livernoismotorsports.com/products/2010-Camaro-Dual-Fuel-Pump-Assembly.html"]Livernois Motorsports Dual Fuel Pump Upgrade[/URL] Precision Industries Converter Built to Livernois Specs Metco Oversize Crank Pulley Ring Innovators West Oversize Balancer Rotofab/Livernois Cold Air Intake (Available soon) Stainless Works Longtube Headers & Connection Pipe Hardened Pushrods NGK TR6 Spark Plugs 160 Degree T-Stat GM 90mm Throttle Body Bogart 17” Wheels w/ Slicks & Skinnies Livernois Motorsports Dyno Tune [B]Dyno Results Stock:[/B] 476 RWHP / 476 RWTQ The best pass 100% stock with 110 miles on the odometer was 12.41 @ 115.9 mph. It was traction limited and the track was extremely busy, so I didn’t get a good feel for the car and how to launch it. [B]Dyno Results Modified:[/B] 707 RWHP / 680 RWTQ (Roughly 850 crank HP) [B]Note:[/B] Our tuner Dan Millen was at the track with me all day logging each pass and getting more and more aggressive after each pass, so I’m sure the power was quite a bit higher than what we saw on the dyno. Just a little info on Dan, he is a multi-time 10.5 tire world champion who always sets the bar for the class. His car runs 3.7X @ 204 mph in the 1/8 mile! I wouldn’t hesitate to daily drive the ZL1 with these mods (minus the wheels/tires). I do plan on driving the car to Rodger’s Chevrolet for their show/open house tomorrow, then back to Milan on the stock wheels and Mickey Thompson ET Street Radials to see what it will run on 20’s. The first pass off the trailer today, the car went 10.14 @ 138 MPH. Many of my launches were from just above idle and it was like a bracket car with several 10.0X-10.1X passes @ 138-141 MPH, and FINALLY on the last pass 9.87 @ 142 MPH!! Dan got pretty aggressive with the tune and told me to leave as hard as I could off the converter. We WERE going 9’s on this pass! I did the burnout, staged, then focused… not worrying about my reaction time (it was horrible as you can see), put it on the converter until it felt like it was going to roll forward and let it rip. I knew at the end of the track it was a good pass when I saw 145 mph on the heads up display. We are also currently working with PSI Superchargers to improve the factory blower. Dan runs a PSI screw blower on his 3-Second 200+ MPH 1/8 mile race car. [B]Huge Thanks to:[/B] GM for building an awesome car, Rodger’s Chevrolet, Milan Dragway for the great track, Innovators West, Metco, Mickey Thompson Tires, Precision Industries, Rotofab, Stainless Works… and the technicians at Livernois Motorsports!!!!!! [B]Vehicle Transport Services: [/B] We realize that many of you are quite a distance from our Dearborn Heights, MI location and have interest in our services, but are not able to make the drive due to work and busy schedules. We have a single vehicle enclosed trailer or a two vehicle enclosed trailer if there are two vehicles in close proximity to each other. With this service, you can trust that your car will make it to our location and back to you safely, and with much more power than it arrived with! Cost of this service is very reasonable, but varies based on a distance and the availability of our trailer. All cars are stored safely in doors before and after work is performed. Please call 313-561-5500 or email [email]info@livernoismotorsports.com[/email] for information and pricing. [YT]fx-Rxh2BlPs[/YT] Thank you Regards, Rick LeBlanc Livernois Motorsports [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Sage
IDI-Charlie
Littlefx4
pander952
Topher
flyitaway
jAKe47
phat_raptor
CleverGirl_
N2fire
new raptor
tabvette
Stonehide
tm965
HighwaySentinel
Powerlies
OffroadAlliance.com
Syberspace
Sharpie69
Irregular F150
wakejunky
RaptorMach3p5
Jay_P
Rustfish
nikhsub1
everonward
someday
JayB
raptrrr
encyphered
Skai
FJohnny
GAMike
snareplayer121
Magnetic Personality
BadWRP
Rekkr
SilverGen1
Keith88
mgbond12
jkwalker711
Noplacelikeloam
SurfRaptor
Hambone
Rptrrob702
Badboy4fun_wa
Hard R
Ledbetterjw
2011_Shelby
Gprapfan
... and 47 more.
93,224
56,511
northshoreboarder
Forums
Accept
Learn more…
