Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forums - General Information
Ford Raptor Problems and Questions Forum
Left Turn Signal Blinks to Fast (Sometimes)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="PaloAltoLawyer" data-source="post: 1188092" data-attributes="member: 24574"><p>Hi All: </p><p></p><p>Checking in to see if anyone else has this problem. My 2014 Ford Raptor SCREW's left turn signal occasionally (and increasingly often) blinks too fast. All lights on the left turn signal (front, rear and side mirror) all blink too fast when this happens. It's about 2x+ the normal pace. </p><p></p><p>The thing is that it only does it sometimes. A few weeks ago it would happen generally the first few minutes after startup then stop. Most of the time it would not happen again until I turned off the vehicle, but occasionally it would pop up for a few turns then go away again in the same drive. </p><p></p><p>Then for the next week or so it never happened at all in any drive. Then three days ago it started happening again intermittently. And since last night it basically happens all the time and hasn't returned to normal pace during a drive as it normally did. </p><p></p><p>I already walked around the truck with the signal on (both when its acting normally and when its too fast) and all blinker lights are lighting up. I only tried the left turn signal rights when doing this method though (i.e., I did not look at the right turn signal lights). </p><p></p><p>Has anyone had this happen or know of a solution to try? </p><p></p><p>Thanks in advance!</p></blockquote><p></p>
[QUOTE="PaloAltoLawyer, post: 1188092, member: 24574"] Hi All: Checking in to see if anyone else has this problem. My 2014 Ford Raptor SCREW's left turn signal occasionally (and increasingly often) blinks too fast. All lights on the left turn signal (front, rear and side mirror) all blink too fast when this happens. It's about 2x+ the normal pace. The thing is that it only does it sometimes. A few weeks ago it would happen generally the first few minutes after startup then stop. Most of the time it would not happen again until I turned off the vehicle, but occasionally it would pop up for a few turns then go away again in the same drive. Then for the next week or so it never happened at all in any drive. Then three days ago it started happening again intermittently. And since last night it basically happens all the time and hasn't returned to normal pace during a drive as it normally did. I already walked around the truck with the signal on (both when its acting normally and when its too fast) and all blinker lights are lighting up. I only tried the left turn signal rights when doing this method though (i.e., I did not look at the right turn signal lights). Has anyone had this happen or know of a solution to try? Thanks in advance! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
k3k0a808
k2damax
KMO
Sand_Limo
flyitaway
Dameatz
FP_RPTR
ReluctantRaptorGuy
zapp
olverac
beemerb0y
wyomingraptor
pchmotoho
Yfz rock
MagneticScrew
JD05
taquitos
Raptr1229
Wristdoc
jimmyjamm
2011_Shelby
nikhsub1
joeyrotorhead
93,349
56,636
RAPTORHD
Forums
Accept
Learn more…
