Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Lighting Forum [GEN 2]
IDJMTOY 10" LED Install
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Grayden" data-source="post: 1190434" data-attributes="member: 23687"><p>I would say that it looks like MKOMERTZ and I decided to mount the lights higher on his. The upper hole on the bumper that has the small 45* support bracket is the hole we used. You can see how low yours are if you compare it to his pictures. Let me know if that helps. Also make sure you loosen the nuts enough, I think the mounting area is knurled to help lock them in place while tightened .</p></blockquote><p></p>
[QUOTE="Grayden, post: 1190434, member: 23687"] I would say that it looks like MKOMERTZ and I decided to mount the lights higher on his. The upper hole on the bumper that has the small 45* support bracket is the hole we used. You can see how low yours are if you compare it to his pictures. Let me know if that helps. Also make sure you loosen the nuts enough, I think the mounting area is knurled to help lock them in place while tightened . [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
mrmagoo
GEN3LV
ILM_Raptor
dvm
Jacobr56
white_dc
vill
shayb16
93,395
56,671
IDBRUIN
Forums
Accept
Learn more…
