Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Getting King 3.0's on the front and back. Anything I should know before hand?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="letsgetthisdone" data-source="post: 1551735" data-attributes="member: 32303"><p>It’s like anything else with two shocks per corner, coilover and an external bypass. </p><p></p><p>The multiple holes in the bottom only allow as much flow as the two bleed holes in the middle of the inner body allow. I don’t remember how many there are, I think there’s two. But you could have 37 holes in the bottom, it’s only bypassing as much as the two return holes allow. Which is why I said the holes at the bottom are mostly for flow to the reservoir as they greatly out number the wholes that create a bypass circuit, especially on rebound. On compression they’re needed because the flow is much great with higher shaft speed.</p><p></p><p>I’m still lost as to how you think the stock gen2 shocks are so terrible. Lmao</p></blockquote><p></p>
[QUOTE="letsgetthisdone, post: 1551735, member: 32303"] It’s like anything else with two shocks per corner, coilover and an external bypass. The multiple holes in the bottom only allow as much flow as the two bleed holes in the middle of the inner body allow. I don’t remember how many there are, I think there’s two. But you could have 37 holes in the bottom, it’s only bypassing as much as the two return holes allow. Which is why I said the holes at the bottom are mostly for flow to the reservoir as they greatly out number the wholes that create a bypass circuit, especially on rebound. On compression they’re needed because the flow is much great with higher shaft speed. I’m still lost as to how you think the stock gen2 shocks are so terrible. Lmao [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
2010 Shelby
Jayden
Gator85
NASSTY
Stingray23
sct
jm77
wyomingraptor
Butterz
HighNoon
93,292
56,577
spc187
Forums
Accept
Learn more…
