Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
FOX 3.0 first on road driving impressions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MCM34" data-source="post: 1311591" data-attributes="member: 3433"><p>Thanks, that helps a bunch. I've already started messing with them and a couple of clicks is noticeable. 1st thing I noticed was neither shock was set the same from factory. Short compression tube one was at 14 and the other at 22 from closed. Also one of my short tubes only has 26 clicks and all the other compression tubes have 29. Seems to be par for the course for Fox, my new Fox 36 grip 2 on one of my mountain bikes has 32 clicks of LSC and it's only supposed to have 16, early production issue they say.</p></blockquote><p></p>
[QUOTE="MCM34, post: 1311591, member: 3433"] Thanks, that helps a bunch. I've already started messing with them and a couple of clicks is noticeable. 1st thing I noticed was neither shock was set the same from factory. Short compression tube one was at 14 and the other at 22 from closed. Also one of my short tubes only has 26 clicks and all the other compression tubes have 29. Seems to be par for the course for Fox, my new Fox 36 grip 2 on one of my mountain bikes has 32 clicks of LSC and it's only supposed to have 16, early production issue they say. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
k3k0a808
Gator85
oliverb
mobiia
shigman
julien194b
wyomingraptor
ReluctantRaptorGuy
acerikk
nemx735
someday
nomis88
roger7254
samwelll
hingedthinker
Hal993
jasfergus
Badboy4fun_wa
tm965
Jacobr56
Romes86
ksgries
Sparda1123
93,240
56,530
osten100
Forums
Accept
Learn more…
