Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford SVT Raptor General Discussions [GEN 1]
Door key pad code
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Gruffy" data-source="post: 1373874" data-attributes="member: 14678"><p> <ul> <li data-xf-list-type="ul">The first thing to get Keyless Entry Door Factory Code you need to locate the Smart Junction Box (SJB).</li> <li data-xf-list-type="ul">On the 2010-2018 Ford F-150, the Smart Junction Box (SJB) is located under the right-hand side of the instrument panel. You will need to remove the trim panel for access to the SJB box, pull the panel toward you and swing it out away from the side and remove it.</li> <li data-xf-list-type="ul">It will show the code see attached picture</li> </ul><p></p><p>[ATTACH=full]125921[/ATTACH]</p></blockquote><p></p>
[QUOTE="Gruffy, post: 1373874, member: 14678"] [LIST] [*]The first thing to get Keyless Entry Door Factory Code you need to locate the Smart Junction Box (SJB). [*]On the 2010-2018 Ford F-150, the Smart Junction Box (SJB) is located under the right-hand side of the instrument panel. You will need to remove the trim panel for access to the SJB box, pull the panel toward you and swing it out away from the side and remove it. [*]It will show the code see attached picture [/LIST] [ATTACH=full]125921[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
jzweedyk
stevenstommyboy1
Kru
20Ecoboost17
MFouts
Tristan Shepersky
petrolhead
RAPTORSCHIM
jdm_sixtwo
Gashawg
Jhollowell
MikeyP87
Wampa
BigTomJR
Alan Van
Kyle@Apollo-Optics
sukid
pughde
Spike Spiegel
Punkur67
Ramjet
goblues38
icecoldak
njhummer18
Amorica
Sbrewer
Lifted&slifted
Jordan Bocko
damaschke
TiFJ
oswiff
BadWRP
Wim
Waaptuh
shigman
ST3V3LU1S
RaptorAU
stevierayb
ograptor
CleverGirl_
TomDirt
Raptorbert
snt505
EliteAGDan
hamster
DLaw0522
Roscoe S
e10tran
Latchkey Kid
Simplejack
... and 43 more.
93,304
56,593
sdavis007
Forums
Door key pad code
Accept
Learn more…
