Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
Deaver and SVC Adj Bump Install & Review
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mezger" data-source="post: 1306675" data-attributes="member: 28569"><p>Regarding the SVC strike pad thickness, with the wire tie metal tab removed from the diff, it has supports which mate with the axle tube directly below where strikes should occur; IMO, this portion of the design looks well engineered. I did a shakedown run on mine yesterday evening, and there is a noticeable improvement in skittishness (Deavers). I will say that I do notice when I get into the bump stops, but I have no experience with hydraulic bumps so I don't have a reference whether or not they're harsh.</p><p></p><p>I summed the weights of what went in and what came out, accurate to my bathroom scale's error:</p><p></p><p>SVC bump stop kit (includes hardware): +43.9 lb</p><p>Stock springs, blocks, bumps: -136 lb</p><p>Deaver springs: +204.8 lb</p><p></p><p>Overall, these add 112 lbs to the truck.</p><p></p><p>Height at fender with OEM springs: 42.0". Height at rear fender with Deavers +2 (non HD) and SVC pads immediately after installation: ~42.25", most of the 0.25" is the SVC pads. Effectively, I saw no change in ride height. Height after a couple days and driving ~100 miles: 42.0", but this is with fuel added, so I claim no 'settling'. Will measure again with ~1/4 tank of fuel to see if it changes, but I'm not expecting it to.</p><p></p><p>FWIW, I ended up contacting both SVC and Deaver for documentation on torque specs and installation details. Deaver didn't respond to an email inquiry, but they picked up their phone on the second ring. Both were very helpful.</p></blockquote><p></p>
[QUOTE="mezger, post: 1306675, member: 28569"] Regarding the SVC strike pad thickness, with the wire tie metal tab removed from the diff, it has supports which mate with the axle tube directly below where strikes should occur; IMO, this portion of the design looks well engineered. I did a shakedown run on mine yesterday evening, and there is a noticeable improvement in skittishness (Deavers). I will say that I do notice when I get into the bump stops, but I have no experience with hydraulic bumps so I don't have a reference whether or not they're harsh. I summed the weights of what went in and what came out, accurate to my bathroom scale's error: SVC bump stop kit (includes hardware): +43.9 lb Stock springs, blocks, bumps: -136 lb Deaver springs: +204.8 lb Overall, these add 112 lbs to the truck. Height at fender with OEM springs: 42.0". Height at rear fender with Deavers +2 (non HD) and SVC pads immediately after installation: ~42.25", most of the 0.25" is the SVC pads. Effectively, I saw no change in ride height. Height after a couple days and driving ~100 miles: 42.0", but this is with fuel added, so I claim no 'settling'. Will measure again with ~1/4 tank of fuel to see if it changes, but I'm not expecting it to. FWIW, I ended up contacting both SVC and Deaver for documentation on torque specs and installation details. Deaver didn't respond to an email inquiry, but they picked up their phone on the second ring. Both were very helpful. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Telecaster480
bellnghmrider
Butterz
nelsonr103
Braaaaptor
RobSpring661
icecoldak
james9
BBQness
sf2360
David333
Stonehide
RNA352
Whoops
KMO
jgsmithsae
shigman
3Dog
mobin
pattmarsons
Hard R
Titan_Uranus
Space Ghost
JD05
GreenGoblin
downforce137
elpechedepeche
Ruger
jak405817
Justbob
Raptor Rob
wyomingraptor
BoostCreep
pat247
taquitos
93,190
56,469
ngodavid23
Forums
Accept
Learn more…
