Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
3.0 service intervals, rebuilds?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Trick.Raptor" data-source="post: 1361712" data-attributes="member: 16456"><p>Generally 3.0 maintenance follows the same for OEM shocks. Rebuild at 50k if mostly driving on the streets (though I believe if you never go off-road you can probably go 75k). 10k-40k for those who go off-road depending on how much abuse your Raptor may see.</p><p></p><p>I have 40k on my front 3.0's and they are starting to feel tired while off-road. I had a seal failure with my rear Fox 3.0 shocks when they were 20k mark and we when opened them the fluid looked good/fresh. We still put fresh fluid since they were open in and either way all four will be rebuilt in the next month or so.</p><p></p><p></p><p>--</p></blockquote><p></p>
[QUOTE="Trick.Raptor, post: 1361712, member: 16456"] Generally 3.0 maintenance follows the same for OEM shocks. Rebuild at 50k if mostly driving on the streets (though I believe if you never go off-road you can probably go 75k). 10k-40k for those who go off-road depending on how much abuse your Raptor may see. I have 40k on my front 3.0's and they are starting to feel tired while off-road. I had a seal failure with my rear Fox 3.0 shocks when they were 20k mark and we when opened them the fluid looked good/fresh. We still put fresh fluid since they were open in and either way all four will be rebuilt in the next month or so. -- [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
scroper
Corsarych
vill
nelsonr103
93,180
56,460
khunter
Forums
Accept
Learn more…
