Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
2018 SCrew mileage question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="OriginalToken" data-source="post: 1280018" data-attributes="member: 27465"><p>If my experience is any indicator, then yes, it absolutely can be right.</p><p></p><p>First thing I have noticed is the trip computer calculated mileage tends to be a bit long. Mine may indicate 18 MPG when the reality is more like 17 or a tad less. Or if it shows 15.5 I am someplace in the high 14’s. Whatever the case my indicated mileage has always been higher than reality.</p><p></p><p>Next thing I have noticed is that mileage in this truck is very drag dependent. I typically get better mileage at city speeds, even factoring traffic lights and periodic stops, or low speed highway stuff, than I do at my “normal” (a bit over posted limit) highway speeds. At 45 MPH I can get well over 25 MPG for extended periods of time.</p><p></p><p>An example. My daily commute is 32 miles one way. 5 miles of it in light city traffic, the rest on either 55 or 65 MPH posted two lanes, with a couple of stop signs. If I am not hard on the starts and I do exactly the speed limits I can get over 19 MPG across the week. Calculated by mileage and amount of fuel used, not on the trip MPG indicator. But, driving it more “normal” for me, including 6 to 12 MPH over anytime I am not inside the city (I don’t exceed posted limits in city) and crisper starts, I get more like 16 to 17 MPG across the week. If I get a little spirited I can push that down to 14 to 15 MPG pretty easy.</p><p></p><p>When I drive to the big city (120 miles away) I start getting better mileage once I get to the city. The entire trip going there I am typically at speed (75 – 85), and drag is killing the MPG. There are very real differences in MPG between say 60 and 70, and a bigger step from 70 to 80+. Once I get to the city and in traffic (as long as it is not honest stop and go) I often get better mileage. </p><p></p><p>Off road though, yeah, mileage sucks there <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /> Most of my 4x4 is in 4 LO, and 10 MPG averages, or less, are common.</p><p></p><p>(edit) I might add, use of the Adaptive Cruise Control in traffic kills the mileage. It always decelerates and accelerates a bit harder than required. I like the feature, but it does not help gas mileage at all.</p><p></p><p>T!</p></blockquote><p></p>
[QUOTE="OriginalToken, post: 1280018, member: 27465"] If my experience is any indicator, then yes, it absolutely can be right. First thing I have noticed is the trip computer calculated mileage tends to be a bit long. Mine may indicate 18 MPG when the reality is more like 17 or a tad less. Or if it shows 15.5 I am someplace in the high 14’s. Whatever the case my indicated mileage has always been higher than reality. Next thing I have noticed is that mileage in this truck is very drag dependent. I typically get better mileage at city speeds, even factoring traffic lights and periodic stops, or low speed highway stuff, than I do at my “normal” (a bit over posted limit) highway speeds. At 45 MPH I can get well over 25 MPG for extended periods of time. An example. My daily commute is 32 miles one way. 5 miles of it in light city traffic, the rest on either 55 or 65 MPH posted two lanes, with a couple of stop signs. If I am not hard on the starts and I do exactly the speed limits I can get over 19 MPG across the week. Calculated by mileage and amount of fuel used, not on the trip MPG indicator. But, driving it more “normal” for me, including 6 to 12 MPH over anytime I am not inside the city (I don’t exceed posted limits in city) and crisper starts, I get more like 16 to 17 MPG across the week. If I get a little spirited I can push that down to 14 to 15 MPG pretty easy. When I drive to the big city (120 miles away) I start getting better mileage once I get to the city. The entire trip going there I am typically at speed (75 – 85), and drag is killing the MPG. There are very real differences in MPG between say 60 and 70, and a bigger step from 70 to 80+. Once I get to the city and in traffic (as long as it is not honest stop and go) I often get better mileage. Off road though, yeah, mileage sucks there ;) Most of my 4x4 is in 4 LO, and 10 MPG averages, or less, are common. (edit) I might add, use of the Adaptive Cruise Control in traffic kills the mileage. It always decelerates and accelerates a bit harder than required. I like the feature, but it does not help gas mileage at all. T! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
buckmark
Gator85
SlickTrick
DTZ
WP13
k2damax
fordfreek
zaiiake
BfloRaptor
mlax
Dawn
shayb16
93,411
56,694
forcefed23
Forums
Accept
Learn more…
