Whip Flag Mounting
Woolaroc
Oklahoma
Wanting to go to Little Sahara (OK) in a couple weeks and they require a 6"x12" flag on a pole 10' above ground level. I have a tonneau cover I'd like to leave on. Is there any way to mount one of these? Possibly a hitch mount solution? Any recommendations on manufacturer? Amazon doesn't seem to have much in this regard.
Woolaroc
Woolaroc
Oklahoma
I got a tow hook mount from Swarfworks. I haven't mounted it yet so can't give a review, but it appears to be good quality.
Wonder if it would scratch up the tow hook. I still want to look good in the starbucks drive through. ;)
CoronaRaptor
CANADA
The only problem with flag mounts on the outside of the box, is that the pole whips against the tailgate edge at the top, make sure you wrap a bit of foam tape on the pole where it would hit the back of your truck.
dilmorecg
Seattle, WA
I made my own out of a shackle hitch with the shackle removed and hitch on its side. Got a longer bolt to the end of the flag pole and bolted it through. Worked great and easily removable. Just remember to also get some pipe insulation or a noodle to wrap around the pole so it doesnt scratch your paint. Here is the best pic I have.
bignatelvhc
Oklahoma City
oooo a fellow Okie here, ive been wanting to hit up little Sahara also and have a bed cover. i might try that noodle idea. or just say screw it and take the cover off for the weekend.
baja619
My buddy makes a flag pole / umbrella mounting kit. The whole deal is super solid and made for serious go fast off road hauling (flags up / umbrellas stowed).
This config does not allow for the bed cover to be fully closed when using umbrella or flag.
https://dirtdynamix.com/
Also I cannot say enough good things about https://www.buggywhip.com/
jondle
San Diego
I would go without the cover and mount the whip to your spare tire. If you have a rack, a tubing mount is easy to find. If you just ratchet strap, it should be easy to mount something to the wheel that could easily be removed if you needed the spare.
Magnetic is another really easy option. I ran a magnetic antenna whip and very rarely had issues with it coming off. Only issues were when I hit a branch.
