I just don't get the school girl giggles the same way with a sc as I do with the way the power comes on with a turbo. I'm really hoping that @
englishrodder will provide some feedback on his kit.
Sorry been crazy at work and haven't come on the forum for a few weeks!
The Hellion kit is built very well, it is a rite pain in the ass to fit everything though and definitely needs the off road Y-pipe to free up performance and spooling time.
Link to some info here on HP - we made 643RWHP
http://www.fordraptorforum.com/f24/my-hellion-twin-turbo-raptor-643rwhp-40581/
Now i havent been without issues, the rocker cover PCV set up routes the pipes into the air-filters - even with modest boost (anything over 5 PSI) we were sucking in a ton of vapour into the combustion cycle that was then creating havoc on the fuel map etc
That was fixed by moving to a dual Moroso catch can set up - that i just empty on a regular basis.
Getting the best out of the tune has been challenging, I didnt use the tune that went with the kit but worked with Rob Williams to build a custom tune - this has taken 3-4 sessions to get correct. We had issues with it actually spooling up too fast the controling the transmission shifts - a lot of work went into getting the trans to react fast enough.
Ive had problems with the Turbo's themselves, both seals went on them as well after only 3 months and about 1500 miles - this wasnt due to dust or intake issues as we can see (Unless it was impacted by the PCV issue...maybe??)
As for how sturdy are the mountings, Ive taken it off-road twice at speed and once over a ton of rocky sections we have here in CO.
Ive added the TSS oil pump gears and adding a new drive shaft this weekend. Plus the AFE deep pan for the trans and will add a remove cooler (In the bed somehere as no room up front now)
Its a serious blast to drive, on Boost she is a killing machine, but best of all on the highway at 75 at only 1PSI with normal driving i get nearly 15mpg!! - best of both worlds
Hope this helps
Will get some more pics next week after fitting the new Turbos with good seals!
Thanks
David
