UPR products at Got Exhaust
Nick@GotExhaust
SC
Got Exhaust is now proudly offering UPR products
UPR makes many high quality, high performing parts for many vehicles, from catch cans to full suspension packages. There are well known among the racing communities and enthusiasts.
UPR offers one of the best catch cans in the industry. We offer UPR's catch cans for the 1st and 2nd Gen Raptors!
The Ultimate Oil Separator for your 2017 to present Ford F150 or Raptor 3.5 Ecoboost Truck. The UPR Plug N Play� Dual Valve Catch Can with UPR Pro-Series Check Valves one way electronic pressure sensor system. You can be sure that no other manufacturer can give you the level of quality and performance that UPR Plug N Play� Dual Valve Catch Can with UPR Pro-Series Check Valves consistently deliver. Offering the largest capacity in a compact design to be sure that it will eliminate oil vapors on vehicles that are normally aspirated or power added equipped.
This system is designed to require less maintenance between oil changes and eliminate the amount of moisture that's collected from controlling condensation better by being mounted in the engine bay. Our Patented Multi-Stage Multi-Chamber internal design is the best for controlling oil vapor and mist even in the hottest mounting locations.
In turn, our new design was developed to work the best in the engine bay without any second guessing of its true performance capabilities. Does require drilling of your factory inlet for the WOT connection.
Most importantly this system keeps your PCV system performing with the level of protection and performance it deserves by not filling the intake and CAC / Inter-cooler full of oil like the factory designed system does.
Manufactured from Domestic T-6 6061 Aluminum bar stock and finished off using only the best Diamond cutters to exceed your expectations of what a superior product should fit and look like.
Developed to eliminate oil from entering your intake by engine blow-by, which channels oil and trash into your direct air stream from the valve train. This is a common problem on both brand new and especially older engines, which just suffer more from blow by due to wear and tear.
The most common problem is making your car emit light blueish white smoke upon start up or even during normal driving. The throttle body handles your main air stream and has a breather tube running from the crankcase to the throttle body. The vacuum from the incoming airstream and positive pressure in the crankcase combine to get oil in the air tract.
Every car and vehicle is set up this way to help eliminate the pressure build-up in the bottom end of your engine enabling the piston to move up and down with less resistance.
These catch cans feature a containment system and separator that force all the debris to get captured and contained in the filter while still allowing airflow thus maintaining full function of the breather system.
This catch can has been long awaited and is one of the most needed items for the late model performance world. We have had countless customers install our new Aerospace Mustang Billet Catch Can and get immediate results in both idle quality and vehicle performance.
Another key problem caused by oil in the intake is that it reduces the octane of your fuel and causes detonation especially in turbo, supercharger and nitrous applications.
Message me for details and forum pricing!
Nick@GotExhaust
Nick@GotExhaust
SC
message us for pricing to help start keeping the insides of your engine components cleaner!
Nick@GotExhaust
Nick@GotExhaust
SC
Message us for pricing on the best performing Catch Can on the market!
Nick@GotExhaust
Nick@GotExhaust
SC
Contact us for pricing on one of the best Catch cans on the market!
Staff online
93,180
56,460
khunter
