Speedometer is off by 5mph
ColoradoBoss
Took a road trip this weekend and noticed my speedo is 5mph slower. I have changed tires to a 35/12.5/17 but I did do a tire size correction with the Cobb AP. I'm really scratching my head on this one since the speedo should only be off by 1% or so. Don't know if any one has any suggestions or not? I have altered the AFE bias for a more accurate MPG reading. I'm not sure if that would affect the speedo, I got the information about changing the AFE bias from the f150 forums.
FordTechOne
Detroit
Not every tire of the same spec will have the same circumference. Does Cobb allow for tire circumference to be used instead of tire size?
ghost410
Westchester, NY
Is it consistently off by 5mph at all speeds or at a certain speed? If you could calculate the exact percentage off it is, should be easy to correct in the Cobb. If it’s a consistent 5mph at all speeds, there’s other issues
ColoradoBoss
ColoradoBoss
It appears to be consistently off at all speeds. only other thing that i can think of is the AFE bias, so i'm thinking of putting that back to stock and the cobb tire size back to stock and check my speed again.
ghost410
Westchester, NY
If it was the tire size correction in the Cobb causing the issue it would be a set percentage do The mph it was off would increase with speed. So I’d rule that out
snt505
AZ
I don't believe so, but I will check when I get home form work.
Cobb does allow you to put whatever height you want in there. I think stock the number is like 33.4" (less than even the ideal size of 34.35"). I have had Yokohama 37s that are 36.8 or so without a load and now BFG 37s that are like 36.3 unloaded. I have just adjusted that number to compensate, but always go a little lower than the unloaded actual height.
Steve-PNW
Seattle
can confirm
