Moroso Air/Oil Separator
R1jamn
I installed the Moroso catch can on my '14 scab while it was still on the dealer lot.
I changed some of the components of the kit using different hoses, connectors, O-rings, retaining screen and installed more of the mesh screen material and some other details were changed too.
My Raptor has 2000 miles on the clock and I performed it's first oil change today.
I also opened up the Moroso catch can to dump it out for the first time.
There was a significant amount of oil in it. I'm happy with the Moroso and it's ability to keep the oil out of the intake.
Here is a description of the kit and what I improvised on.
Moroso Air/Oil Catch Can Kit #85607 – small body (black anodize).
I had the stainless steel bracket powder coated (black) (compound TGIC Polyester) (JR Powder Coating) The Moroso bracket is made from series 409 stainless steel (crap stainless steel).
I buffed down all the edges on the bracket because it had sharp edges and corners everywhere. I used a Norton Bear Tex wheel for this process. Then I had it powder coated. ($40)
I fitted the Moroso catch can with XRP 90 deg aluminum fittings (black anodize) (size -8 AN) (it screws into the catch can with 3/8-18 NPT)
I used teflon tape on the NPT threads of the fittings and copper anti-seize grease on the straight thread for the hose fittings.
I fitted the Russell Performance hose with XRP straight barbed aluminum fittings (black anodized)(size -8 AN)
I used Russell Performance Twist-Lok hose (color is Blue). It’s a push-on hose with a CPE synthetic rubber liner (chlorinated polyethylene) with a reinforced fabric braid (size -8 AN/.500” I.D.)
(lengths 13.” and 20.”) (rated for 250 psi) (temp range -40 to +350 F). I ordered it from Summit Racing (10 ft. length)
I bought an extra pcv to induction hose with the fittings from FordParts.com and removed the hose from fittings with a heat gun.
I kept the original one from the Raptor just in case the Moroso leaks (I'm sure it won't though)
I used Norma Torro hose clamps (German Style) to secure the hose to the barbs (material is W4 which is a great 300 series SS)
Installed a Fluorocarbon (FKM) 75-durometer (black) o-ring (size -135) for the catch can. Installed a Viton Fluorocarbon o-ring for the Ford nipples.
I bought “Super Lube” a silicon o-ring grease to lube the o-rings with. (made for Fluorocarbon o-rings)
I purchased an extra Moroso mesh screen for the catch can (part #85472060/4ft.) thru Lethal Performance. I had to cut it in half and then roll it up with the ones in the catch can for each chamber.
I purchased 3/8 inch and 1/4 inch washers for the 1/4-20 bracket bolts and 10mm strut tower studs.
I purchased new Ford Nylock nuts for the tower bracket hold down studs, as per Ford service manual. Tighten new Nylock nuts down to 30 lb-ft.
I purchased the XRP fittings from TMR in Orange, California, 714-771-1348
I improvised the retainer plate for the mesh screen. It is cheap cast aluminum .030 thick. I made my own retaining plate made out of 6061-T6 that is .125 thick.
Seeing how much oil was trapped in this kit, I should have purchased the large Moroso catch can.
The Moroso captured 60 ml of oil (2.0 fl oz).
R1jamn
R1jamn
A few more pics
MS Raptor
MS
R1 - thanks for the great write up. I need this for my new truck. Maybe if I get to work on this now I will have it done before my truck gets here late Feb/early March. I am not that mechanical but willing to give it a best effort
---------- Post added at 10:19 PM ---------- Previous post was at 09:59 PM ----------
Where did you purchase the catch can? I googled it but only found 2 dealers I am not familiar with.
R1jamn
R1jamn
Hey MS,
I purchased the Moroso kit from Lethal performance.
I highly recommend this kit for your new Raptor. Install it ASAP.
You don't neccesarily need to improvise the kit as I have.
I would let someone that is a wrench hand take care of the install for you though.
The reward of working on your own rig is great also. Just don't get in to deep and have an OH SHIT moment.
J DAMAGE
NJ
Used the universal kits, did both sides, being I had them form a project I never completed, worked out for the better.
R1jamn
R1jamn
Hey J,
What amount of oil is your Moroso catching on the drivers side?
Some have stated that not much is going thru on the drivers side.
I will install one on the drivers side too if it needs it.
J DAMAGE
NJ
Hey J,
I will install one on the drivers side too if it needs it.[/quote]
Nothing on the drivers side, bone dry, I check them every 4-6 weeks, passenger side gets 2 oz at any giving time, like others have stated, unless your super charged you probably wont see it.
MS Raptor
MS
I just ordered the Moroso kit from Amazon for $160.15 includes shipping if anyone else is interested in purchasing. I thought this was a good price.
93,180
56,460
khunter
