Left exhausts seats lower?
SoxFan
Virginia
Loosen the nuts and adjust, you can make either side move if you like one height over the other.....may need to loosen clamps for the rear sections if the tailpipes will not move freely
Tbogo
TX
Thank you so if i loosen up the driver side it will go back up? Or u mean i need to tighten it?
Yeah, I have the same issue. Please let us know what your fix ends up being. It doesn't look like an easy fix.
DMays
Tennessee
It’s a really easy fix. If you crawl under there you’ll see a clamp with a nut that is on the last piece of the exhaust pipe. Loosen that nut and you can turn the pipe either direction to raise or lower the tip. Won’t take 5 minutes once you get under there.
AvalancheGrey2017
USA
i think its a 10mm? if its not its a 13. should take you about 5 mins, minus breaking the rust loose. try the mounting bracket near the tow hook first. If you need more drastic movement you may need to loosen the clamp where it connects to the muffler section as mentioned above. had this same issue.
Tbogo
TX
Absolutely right 5 min job two 10 mm nuts that hold the mounting bracket at the exhaust tip hook did the trick. Thanks for the support info!
